So, what's the secret? I've pulled it back some and can see what looks like tabs, but they don't move or disengage when I press on them. I'd really rather not break any tabs...
Thanks.
Replacing seat covers, can't remove the *&%#@ airbag cover
- TrueWildMan
- Year and Trim: 2001 Pontiac Bonneville SSEi
SC is me spinach!
Dark Bronzemist 2001 SSEi
Intense PCM, Intense FWI, Intense modular 3.40" pulley, 1.9 Yella Terra roller rockers, LS6 Medium Load valve springs, Magnaflow mufflers, hi-flo cat, exhaust tips.
- harofreak00
Re: Replacing seat covers, can't remove the *&%#@ airbag cov
Its not an airbag cover, its the whole assembly. You have to remove the whole thing. There are 2 - 10mm nuts that you access through the zipper on the back of the seat. You will angle the rear of it out, and then a push in retainer holds the rest of it in. Pull it out.
- TrueWildMan
harofreak00 wrote:Its not an airbag cover, its the whole assembly. You have to remove the whole thing. There are 2 - 10mm nuts that you access through the zipper on the back of the seat. You will angle the rear of it out, and then a push in retainer holds the rest of it in. Pull it out.
Alright, thanks. I'll know for next time. Got it all back together now. I pulled the cover off the seat and found that there are no heat elements, even though it appears there are supposed to be. So, I put the project on hold until I can locate some heat pads.... *grumble*...
SC is me spinach!
- harofreak00
The heat elements are built into the covers. You won't be able to see them, except for the wires coming out.
- TrueWildMan
Oh, wow...ok. Not sure what I was thinking when I bought these replacement ones, then... Hmmm... I'm sure you told me they were not heated.harofreak00 wrote:The heat elements are built into the covers. You won't be able to see them, except for the wires coming out.
I'll have to look into getting heated ones, I guess.
SC is me spinach!
- harofreak00
I don't even remember what I sold you. Post some pics of the underside of them.
- TrueWildMan
Well, I see that it's not there, I think that's why I thought it was separate. But, here ya go:
SC is me spinach!
