Oil Pressure
Posted: Tue Mar 22, 2011 11:01 pm
by ericm88
I've looked around and I think oil pressure sender might be bad. I wanted to ask to see what you all think. I drove around today and oil pressure was good. Tonight when I got in my car to drive home I noticed the oil pressure sitting around 110 or so, its not all the way pegged out. I checked my oil and it is normal and everything sounds and feels okay. It seems like the oil pressure does rise a little with RPM too. I'm not sure if it is the sending unit. What do you think?
Thanks in advance.
Re: Oil Pressure
Posted: Tue Mar 22, 2011 11:06 pm
by viper8907
Definitely the sender. My started reading high too, and eventually pegged at 120. I just got a new one in this weekend and it reads 60 psi at idle again.
Re: Oil Pressure
Posted: Fri Mar 25, 2011 8:56 pm
by dematka
Yep, I just fixed this. Reading way too high and LEAKING OIL! The sender starts leaking and messes up the reading. Fix two problems with one repair - and it's cheap and easy!
Re: Oil Pressure
Posted: Sat Mar 26, 2011 3:25 pm
by kristie_jeff
Sorry to intrude, but what should the "normal" pressure be? I assume it would change a bit with different oil weights, and maybe with temperature too, but i was curious.
I'm loosing a little bit of oil somewhere that I can't find, and depending on whether or not my pressure is high, maybe I found out why.
Re: Oil Pressure
Posted: Sat Mar 26, 2011 3:35 pm
Normal is subjective to your car. What pressures are you reading? I see about 60 PSI cold idle, 45 PSI hot, 65-70 PSI driving. This is my aeroforce's numerical reading, not my stock gauge.
