Horn keeps blowing fuses
- 92BonnevilleSE
- Posts like an LN3
- Year and Trim: 97 Pontiac GP GT
So this just started recently. I tried to honk my horn at some stupid drunks that darted out in front of my car. Well it sounded funny so I tried it again and it didn't work at all. So the next day, I took a look at it and found that the fuse for the horn was blown. No problem, get another fuse and install it. Simple as that. Well I replaced the fuse and tried the horn and nothing. Checked fuse again, and it was blown. Replaced it again, and same outcome. Has anyone ever had this happen? I checked the wires for maybe a wire that was grounded out but I didn't see anything. Can anyone help?
Joe
Rebuilt L36, Silverstar highs/lows and fogs, new brake lines, rotors, calipers, pads, ZZP Exhaust, Projector Headlights, Tinted Tails and Windows.
Mods to come- LED Tails, HID Kit, Top Swap (springtime)
- Year and Trim: .
Re: Horn keeps blowing fuses
Should be a simple circuit of a relay fuse and switch, you either have a bad horn, wiring or relay.
- 92BonnevilleSE
- Posts like an LN3
After work I'm gonna try another horn on it. Going to my brothers who also has a 97 gp gt with a good horn.
Joe
- 92BonnevilleSE
- Posts like an LN3
Well last night I swapped in my brothers horn from his gp and the problem still occured.
Joe
- Year and Trim: .
Both or just one?
Check the wiring and try swapping the relays. Use a meter and check the resistance through the circuit from the relay to the horns.
Do you have the circuit diagram for them?
- 92BonnevilleSE
- Posts like an LN3
No I dont have a diagram. I put my original horn in his car and it worked just fine but nothing in my car. Even swapped our relays and nothing solved it. Will be digging into it more tomorrow on my day off work. It's not a big problem but just kinda bugs me.
Joe
- Bonnefied_GM
- SSEi Member
- Year and Trim: 1998 SE (w/ SLE package)
I never use my horns on my cars to the point that I forget I have horns.
1992 Chevrolet Lumina base:TOTALED (died at 110k)
1989 Buick Reatta:SOLD (sold at 105k)
1991 Pontiac Bonneville LE:SOLD (sold at 225k)
2001 Cadillac Seville SLS:SOLD (sold at 140k)
1998 Pontiac Bonneville SE:CURRENT (bought w/ 145k)
- Mechanical Mike
- Retired Gearhead
- Year and Trim: 99 SSEi
Pull the relay & see if the fuse blows when you press the button. PM me with an email address if you want a wiring diagram.
2006 Chevy Monte Carlo SS
- 92BonnevilleSE
- Posts like an LN3
Well got the horn somewhat working.. it is more of a click coming from both of them. Does that sound like a bad horn or something?
Joe
keir
- SSEi Member
- Year and Trim: 2000 ssei
...and I just about wear mine out from overuse.Mine is not working currently,hoping it is just a bad fuse.Bonnefied_GM wrote:I never use my horns on my cars to the point that I forget I have horns.
Black 91 SSE-Where it all started....
Red 95 Grand Prix SE-Gone but not forgotten....
Grey 00 SSEI -The current daily driver.
Dark Grey 2011 Dodge Charger-The new flagship.
- willwren
- Retired Admin
- Year and Trim: .
Bonnefied and keir, can we keep this on topic? This is about fixing a broken horn, not general discussion on how much you use one.
- 92BonnevilleSE
- Posts like an LN3
Here is a video of how my horn sounds now. Both of the horns just have a quick honk and isnt loud like they should be.. I think its something in the car itself, I've tried different horns that I know for a fact are good and the same sound comes from them all.. This is what they sounds like.
Joe
- Archon
Try applying 12 volts to the green wire right at the horns. If it still has a problem, check for a bad ground.
