Page 1 of 3
window molding fix for 2000+
Posted: Wed May 21, 2008 8:20 pm
by Gumball
first i purchased Matte Black Vinyl off of ebay. you could also use shiny black.
I taped my paint along the window so as to not scratch my paint.
then carefully pry in an upward motion loose the molding. moving along a bit at a time.
then sanded the molding as to not feel the deteriorated section.
then cut a piece of vinyl wider and longer than the molding.
and placing it on.
then trim away excess vinyl with a new exacto blade.
you can use a finger nail to tuck in any part that may be sticking out.
Then replace the molding by aligning up the clips and push down.
you can see here the before (front window) and after (rear window)
now on to the fronts....A little tricky in my case due to my vent shades along the windows.
as you need to remove the mirror to get the whole molding off.
Mirror removal.
gently pry off the tweeter housing and pull off in an upward fashion.
this corner nut is a B**** to get at.
because of my vent visors I could not get the mirror off. So I thought I would try to lift up on the mirror and pull the molding out.
that didn't work. and now its starting to rain :evil:
so I put the mirror back on and will try again another time.
started to put everything away and the rain stopped :P
OK I'm going to try something else... how about putting the vinyl on while is is ON the car?
lets try.
cut the vinyl to size.and place on.
you can see here where it will not be put on under the mirrors :P
trim off excess with knife.
Not bad really...
so the rear windows were sanded and the front not sanded. I will give it some time to see how well both stick and let you guys know.
FYI it was much easier to work with ON the car than OFF ;)
you just need to be careful with the exacto knife as well have new blades
Re: window molding fix for 2000+
Posted: Wed May 21, 2008 8:50 pm
by myfirstbonnie
Can you give a link to the material you used. Just so we can see exactly what it is you used. I think I will do it to mine to.
Posted: Wed May 21, 2008 8:57 pm
by Pontiacdad
Posted: Wed May 21, 2008 9:02 pm
by crash93ssei
How has that held up over the winter?
Posted: Wed May 21, 2008 9:05 pm
by Gumball
myfirstbonnie wrote:Can you give a link to the material you used. Just so we can see exactly what it is you used. I think I will do it to mine to.
from EBay? I think his name was Big-t
you can search for plotter vinyl and come up with many colors.
this search is for black
http://search.ebay.com/search/search.dl ... arch&fgtp=
now that I think of it. NHolds (one of our vendors) does vinyl sinage.
I bet he could sell you some.
Posted: Wed May 21, 2008 9:08 pm
by Gumball
8 months and still holding up great, even with all my car washes :)
I just directed NHolds to this thread :wink:
Posted: Wed May 21, 2008 9:34 pm
by NHolds
Thanks for the plug... those are pretty good deals on vinyl though. You just have to get a 6+ year vinyl... some don't hold up that well.
Posted: Fri May 23, 2008 1:32 am
by laxmangl
hmmmm some nice shiny vinyl may be in my future soon thanks to you... I wonder which lasts longer the sanded or unsanded...
Posted: Fri May 23, 2008 5:39 am
by TenGHz
Oh wow, this is a great write up. Mine look a bit worse than yours did. I will definitely be doing this!!! Thanks!
:notworthy:
Posted: Fri May 23, 2008 1:03 pm
by HurstGN
NHolds,
Do you use MacTac vinyl? I've found their 9800 series is extremely durable in outdoor use. And decals that I printed and "frog-juiced" have lasted 10 years now. That's applied to glass. The big factor here will be the condition of the trim being applied to.
Posted: Fri May 23, 2008 7:16 pm
by NHolds
Never tried MacTac.... Use mostly 3M, Oracal, Avery...
Posted: Fri May 23, 2008 7:36 pm
by Red Rocket
TenGHz wrote:Oh wow, this is a great write up. Mine look a bit worse than yours did. I will definitely be doing this!!! Thanks!
:notworthy:
x 2
Mine are absolutely horrible and they're the only thing holding my car back from looking perfect. :evil:
Posted: Sat May 24, 2008 6:43 am
by Karl
I just did this last week... (Thank Jimbo) I was able to dislodge my mirrors enough to remove the sill and recover them off the car without removing the door panels.
NHolds, all of these are the same... Any chance of offering precut vinyl strips in different sizes? I've seen carbon fiber vinyl and someone may way to do this as part of a color theme.
Posted: Sat May 24, 2008 6:53 am
by TenGHz
Yeah, I'd be down for some black carbon fiber look-alike vinyl in pre-cut strips. I could buy some off of eBay, but you pretty much have to buy in bulk - not sure what I'd do with 25 feet worth of the stuff... lol
Posted: Sat May 24, 2008 10:38 am
by Gumball
do what I did and pass it along to other members :wink:
your welcome Karl, how did it come out?
Posted: Sat May 24, 2008 11:36 am
by Karl
Crappy cell phone pic.....
I'm not thrilled with it... My sills were pretty bad and I sanded them a little to get them smooth. They're ok for now but I'll probably redo them at one point.
Posted: Sun May 25, 2008 1:17 am
by erics00ls
oh thanks, this also helps me with my imp. :hello2:
Posted: Mon Jun 16, 2008 5:55 pm
by Noah.Dreams
I'm beginning to believe that if I replace the window molding, I may be able resolve a door leak before it starts.
Any ideas?
Posted: Mon Jun 16, 2008 6:53 pm
by Roadtech195
Jim, that looks friggin sweet and I am impressed with your work. You truly have a great looking car. I don't know how much it is on ebay but ricerzone sells the trim blackout tape for a couple of dollars. I did the same thing on my Regal GS, I used electrical tape and it held up for a few years.
Posted: Tue Jul 08, 2008 1:34 pm
by harofreak00
I just did this on my 00. I did the rears right before vacation, thats why it is dirty. I used a black gloss vinyl from NHolds, $16 shipped.
