Fuses Keep Blowing
Posted: Thu Feb 03, 2011 1:51 pm
by Blue_Bonne
In my 94 bonneville, my park lights fuse keep blowing every time I pull the switch out.... I have aftermarket fog lights not factory plugged up to tha factory switch in the car.
Re: Fuses Keep Blowing
Posted: Thu Feb 03, 2011 2:06 pm
by Bonneville92V688
I had this problem with my '94 SSEi...unfortunately I never figured it out.
Replaced the headlight switch, cleaned the grounds, cleaned all the bulb sockets... everything. Hopefully someone can help you on it now... a few years back I was puzzled.
Posted: Thu Feb 03, 2011 2:59 pm
by Blue_Bonne
I put a 30a fuse in there and it didnt blow but the lights are really dimmed
Posted: Thu Feb 03, 2011 3:05 pm
by Bonneville92V688
Never put a higher than specified fuse in.... you will have flames.
Posted: Thu Feb 03, 2011 3:09 pm
:stupid:
Put the stock fuse back in there NOW.
Would your HID's have anything to do with it?
Posted: Thu Feb 03, 2011 3:22 pm
by Blue_Bonne
I put the 15a fuse back in and it blew again but my HID light has a relay with the kit. They work perfectly
Posted: Sat Feb 05, 2011 1:50 am
by Blue_Bonne
So I found out what where the problem is coming from. I unplugged all my lights and plugged them up 1 by 1. Turns out to be the far right side tail lamp. So I have them unplugged at the moment. Quick question... When I turn my right turn signal on, the amber light on the head lamp assembly lights up and stays on (doesn't blank). Weird. I still need help any ideas just let me know.
Posted: Sat Feb 05, 2011 7:39 pm
by Blue_Bonne
3rd day problem solved a wire was grounded out
