Getting the gas out cant syphon it
nunesjeff
- SSE Member
- Year and Trim: 92' SSE 83' F350 460 Dully 61' Willys Wagon
I have fuel in the car I need to get out what's the best way to pump it out... have about 12 gals id like to use since she has gone cittywampus.... I haven't a clue what's wrong either maybe pump finally or coil gone... either way I had to get a 83 f350 to move around in with my 32' 5th wheel don't have money to fix so yea... getting gas out of the tank? How to?
~*Field Mouse*~ Lebanon, Oregon (92 Bonneville SSE) (Dark Polo Metallic Green) "Green Jelly" (Daily Driver) Silver Star Lows, Highs And Fogs What A Bright Idea...
Re: Getting the gas out cant syphon it
Why can't you siphon it? I used one of those cheap squeeze pumps from NAPA to get 20 some gallons out of our 92 1500 when it popped a head gasket. Took a while, but it worked!
nunesjeff
- SSE Member
Hose will go down but won't hit any gas... goes and then stops like half way down the neck... never to the bottom....
- J Wikoff
- Year and Trim: 1992 SSE
Crawl under and remove the vent line hose from by the filler neck. I think you can get a siphon hose in through that hole.
Is there a screen or something in the main filler neck?
- J Wikoff
Something along those lines to keep gas thieves at bay.
- willwren
- Retired Admin
- Year and Trim: .
Yes, there is an anti-siphon screen. Remove the vent line (smaller of the two attached to the tank) as mentioned above.
nunesjeff
- SSE Member
Thankyou I removed the filler neck off tank worked good... Still harder that heck to get the gas out or at least get that hose down! I can at least get the tank out and get into town in my truck...
1fatcat
- Posts like an L67
- Year and Trim: before cars
I use the fuel pump to do it. Just remove the fuel line at the rail, run a hose from it to the other tank, jump the fuel pump relay with a paper clip, sit back and watch. A battery charger can be used if needed to keep the battery full.
