Dual Exhaust
Posted: Thu Nov 11, 2010 5:34 pm
by 2002BonnevilleSE
OK I'm sure this had been asked before but since I didn't find it here goes again.
I'd like to put duals on my SE but not sure what kind and what fits best. :banghead:
Re: Dual Exhaust
Posted: Thu Nov 11, 2010 6:48 pm
by 01bonneSC
You could get a factory unit off an SSEi or SLE. Should fit perfect minus the fact that you dont have dual cutouts in your rear bumper cover.
Re: Dual Exhaust
Posted: Thu Nov 11, 2010 6:56 pm
by 2000Silverbullet
Waste of cash IMO. No benefit.
Re: Dual Exhaust
Posted: Thu Nov 11, 2010 9:57 pm
by BonneMe
Why does everyone get on about bumper cutouts? Plenty of cars don't run cutouts for tips, you just stick it out below the bumper? The SE bumper on 2000+ has a slight bend on each side that's right above where a tip would go anyways...
Besides, looks great to me :wink:
If you're going to do it and want some noise as well, new mufflers will help, but wont really add HP.
Re: Dual Exhaust
Posted: Thu Nov 11, 2010 10:05 pm
by willwren
Your topic title conflicts with your post.
Dual exhaust is separate pipes all the way back for each side of the engine. Difficult and somewhat pointless on a FWD car.
Dual outlets will buy you nothing.
On the Bonnevilles of various generations that had dual outlets, the exhaust is 2.5" diameter all the way back to the muffler. From there, the earlier models (not sure about the 2k) drop down to dual 2.25's.
The surface area (opening of a 2.5" pipe is 4.9".
The dual 2.25's combined are 3.9 x 2 = worthless because you can't get something for nothing.
So are you interested in true dual exhaust, or just dual outlets?
If it's dual outlets, are you expecting a performance gain, or is this cosmetic?
Re: Dual Exhaust
Posted: Fri Nov 12, 2010 10:44 am
by 2002BonnevilleSE
My mistake. I meant dual tips. But if there is no benefit to changing it except for a different sound then not worth the time or effort.
Re: Dual Exhaust
Posted: Fri Nov 12, 2010 2:24 pm
by 01bonneSC
BonneMe wrote:Why does everyone get on about bumper cutouts? Plenty of cars don't run cutouts for tips, you just stick it out below the bumper? The SE bumper on 2000+ has a slight bend on each side that's right above where a tip would go anyways...
I was getting at a fitment issue if he used a unit of an SSEi/SLE. Like where the tips sit they might just rub on the bumper cover without the actual cutouts. IDK. I was just throwing it out as a caution.
Re: Dual Exhaust
Posted: Fri Nov 12, 2010 3:45 pm
by 2000Silverbullet
Because they will scrape on the ground if going up steep inclines.
Mine do sometimes even with the bumper cutouts.
Duals are purely cosmetic in his case. He'd be better off putting the money into new brake rotors. :wink:
Re: Dual Exhaust
Posted: Fri Nov 12, 2010 5:03 pm
I've had my mudflaps scrape, never my tailpipes.
Re: Dual Exhaust
Posted: Fri Nov 12, 2010 6:59 pm
by BonneMe
Stock SE tips don't scrape, why would adding a second do that? The lower edge of the bumper is just higher up.
Re: Dual Exhaust
Posted: Fri Nov 12, 2010 8:28 pm
by alexcoqui
SE tail pipes don't scrape, but SLE & SSEI's do. & I belive they sit lower, so the SE bumper cover won't be an problem.
Re: Dual Exhaust
Posted: Sat Nov 13, 2010 2:07 pm
by smokeysan
I was thinking about doing the same thing but purely for cosmetic reasons.
