Brake Light Stays On
- Blue_Bonne
- Year and Trim: 1994 SE
My 94 bonneville brake light stays on when im driving and just dings until i cut the car off... my brake fluid is full. When i drive my brake would be off. What could be the problem?
- renchjeep
- Posts like an LG3
- Year and Trim: 1994 Bonneville SE 240k Hot Rod
Re: Brake Light Stays On
I am assuming you are talking about the red "brake" warning light on the dash. Here is where I would start:
Sunk float in master cylinder reservoir, bad sensor or wiring/connection at reservoir bottom, parking brake pedal not releasing all the way, bad parking brake warning light switch.
- willwren
- Retired Admin
- Year and Trim: .
In other words, things that would tell you not to drive the car until it's fixed. It's very likely master cylinder related. Is there any sign of leaking fluid on the booster or down the firewall?
- Blue_Bonne
renchjeep wrote:I am assuming you are talking about the red "brake" warning light on the dash. Here is where I would start:
Yea its the brake warning light...
I have no type of leakagewillwren wrote:In other words, things that would tell you not to drive the car until it's fixed. It's very likely master cylinder related. Is there any sign of leaking fluid on the booster or down the firewall?
- skregal
- Posts like an L27
- Year and Trim: 95 SSEi
05 GXP - Location: Missouri
If you unplug the sensor at the bottom of the master cylinder and the light
goes off, you call rule out the parking brake.
That sensor is built into the master cylinder and cannot be replaced separately,
I believe.
If there are no leaks and level is good, the sensor may be bad.
Mine has been unplugged for 3 years for that reason, but I would
not recommend that, unless you are very in-touch with your vehicle.
I believe.
- Blue_Bonne
- skregal
- Posts like an L27
I think that is correct. Someone else should confirm.
- Blue_Bonne
I love bonnevilles and 3.8s I expect to replace parts on a 94 with 165k but geee... breaking my pockets lol. But I got to do what I got to do.
I still havent found any problems I really dont wanna pay someone to look at it and fix it
- willwren
- Retired Admin
- Year and Trim: .
You need to measure your master cylinder for length from the flange that attaches it to the firewall. There are two different lengths.
One is 6 7/8", the other is 8". I'd suspect you have the shorter (mine is longer than yours
) but measure to be sure.
- renchjeep
- Posts like an LG3
Just bought a new, not rebuilt, master cylinder for my 94 se from Autozone for $54.95. Bench-bled it, then bled entire system using Prestone Synthetic DOT 3 fluid. My brakes have never felt better!Blue_Bonne wrote:I love bonnevilles and 3.8s I expect to replace parts on a 94 with 165k but geee... breaking my pockets lol. But I got to do what I got to do.
And, yes, the sensor is built into the reservoir.
