new car has problems..
its840
Year and Trim: 2 wheels and 2 pedals... much cheaper that way...
Post by its840 »
with the charger belt off it runs ok.. with belt on as soon as it gets into boost is boogs down big time.. guy said is was just tuned up..
2000 l67
could it be something as simple as it needs plugs?
Re: new car has problems..
I'd pull plugs and look at the color. Is the Service Engine Soon light on?
its840
Post by its840 »
no lights on.. no codes... idels fine... give it gas (get into boost) and falls on its face....
I hope its just something as simple as that.... (plugs)
Honestly, start with this list. If none of this fixes it, we can go from there.
  • 1987-2005 Bonneville / Buick 3800 Maintenance List
    Run Seafoam through gasoline and intake every 5,000 miles. One pint of Seafoam in a half tank of fuel is a good mix. The intake is optional, but recommended.
    Grease: Ball Joints, Tie Rods Every 8-10k ( Green Grease recommended)
    Air Filter Every 15k (Amsoil EaA, Purolator PureONE)
    PCV Valve Every 30k
    MAF Sensor Element Cleaning/TB Cleaning Every 50k viewtopic.php?f=48&t=1661
    Fuel Filter Every 15-25k (Purolator, AC Delco, WIX)
    Spark Plugs Every 30-50k (NGK TR55 or Autolite 605) (Never Bosch)
    Ignition Wires Every 30-50k (Napa Belden, AC Delco, Autolite Pro, NGK) (Never Taylor or Bosch)
    Oil & Filter Every 5-6k or Every 6 months (Mobil1 or Amsoil)(Mobil1, Purolator PureONE, Amsoil EaO or WIX) (Never Fram) viewtopic.php?f=45&t=214
    *Conventional Oil Every 3k/3 months(Pennzoil with a WIX (Napa), Delco or Purolator filter)
    Transmission Flush or Pan Drop Every 15-20k (Always make sure filter is changed when flushed) http://www.pontiacbonnevilleclub.com/fo ... 45&t=10193
    Cooling System Flush Every 25-50k or 3-5 Years (Peak or Prestone Green Coolant Only) (Never Dexcool)
    Oxygen Sensor Every 80-100k (30k for non-heated) (AC Delco or Denso) (Absolutely never Bosch) viewtopic.php?f=48&t=794
    Accessory Belt Inspect every 15k, replace every 100k, or as needed
    Cabin Air Filter Inspect and Replace every 15k, or as needed in dusty conditions. (Note: 00+ Only)
    Evap Core Cleaning Whenever Needed (Note: 99 and older only) viewtopic.php?f=45&t=2432
    *Special Considerations*
    All 3800s, LG3, LN3, L27, L36, L26, L67 & L32, especially important on vehicles factory installed with orange Havoline Dexcool Antifreeze/Coolant: http://www.dex-cool.net/
    Lower Intake Manifold Gasket Replacement, every 80-100k (ignorance of this can allow coolant to enter your engine oil, this happening can cause irreversible lower engine damage, requiring replacement of subject engine)
    Series II, Naturally Aspirated, RPO:L36:
    Upper Intake Manifold Plenum Replacement, Every 80-100k (ignorance of this can allow coolant to enter your intake manifold, possible damage to occur can be hydrolock, irreversible damage to emissions devices, misfires, etc. Most times, engine replacement is required if ignored long enough.) viewtopic.php?f=53&t=1061
    Series I, II, III RPO Code L67 & L32:
    Change Supercharger Oil; Every 30-50k. (Intense Racing or GM Dealer) viewtopic.php?f=56&t=1690
    Supercharger Belt; Inspect Every 15k, Replace Every 100k or as needed.
10/25/2010 by 00Beast
plugged cat?
SSEi95
Site Owner/Webmaster
'01 Sierra C3
Post by SSEi95 »
harofreak00 wrote:plugged cat?
I was thinking the same thing.
Sounds like a definite possibility to me too.
its840
Post by its840 »
changed plugs and wires and runs fine now.. wow its been like almost 5 yrs (maybe 4) since i sold the GTP... it just gives me that grin agian.. every time i hear that supercharger spin.... lol..
comatoast
Post by comatoast »
its840 wrote:changed plugs and wires and runs fine now.. wow its been like almost 5 yrs (maybe 4) since i sold the GTP... it just gives me that grin agian.. every time i hear that supercharger spin.... lol..
always a good feeling when you get it fixed on the first try, and least expensive :)
Current mods - FWI, Intense 1.0 PCM, 3.4"- 3.5", Intense MPS, AL 104s, 180 Stat , Intense/TG shiftkit, Aeroforce Interceptor scan gauge
Upcoming mods- 1.9 rockers, 105#springs, Headers, 103s, 3.3, tune..
skregal
Year and Trim: 95 SSEi
05 GXP
Post by skregal »
I would go have a talk with that "guy" who "said it was just tuned up" :roll:
