radio controls
bonnelover
radio controls
Post by bonnelover »
if i get an aftermarket radio, will i be able to use my steering wheel controls anymore?
thanks guys
05 SLE
-Other rides: 2010 Buick Lacrosse, 1987 Dodge Dakota, fully restored
November 2010 COTM
Re: radio controls
You'll need a special adapter harness.
bonnelover
Re: radio controls
they will have that at the install shop?
05 SLE
November 2010 COTM
Re: radio controls
Honestly, unless you have a local place that you know does incredible work, I wouldn't let anyone do this on your car. These are notoriously hard to put Aftermarket HU's in, and most places mess the easy ones up.
I highly doubt they'd have the harness in stock.
bonnelover
Re: radio controls
guess i will be stuck with just looking at the controls and not using them, if i get an aftermarket radio lol
05 SLE
November 2010 COTM
yonkerse
Re: radio controls
Post by yonkerse »
Beast, you hit this one on the head...kinda like most posts you reply to!
I was looking at this awhile back, and they do make a special harness that will allow the controls to still be used, but the harness alone is $150 and the shops i talked to around here didn't carry it. When I was looking at different HU, i was looking at spending around $800 for the head unit i wanted (one large enough to cover the entire hole so it would look decent) and the harness and that price was installing it myself...
I decided to hold off on the HU, but did a complete Alpine speaker upgrade which really improved the sound of my car. My car came with TERRIBLE factory speakers which were completely paper and sounded terrible.
So my two cents would be to replace your speakers (i went with a complete Alpine Type S upgrade for $220, installed myself in about 3-4 hours) and see how you like the sound then!
Eric
A few mods..
bonnelover
Re: radio controls
thanks Eric
05 SLE
November 2010 COTM
Re: radio controls
Honestly, if you get the right adapter, wiring up an aftermarket HU is easy. I'm sure you can DIY.
swampthing
Re: radio controls
Post by swampthing »
I have a steering wheel adapter im not using anymore if anybody wants to make me an offer
Current fleet:
phoenix_flame220
Year and Trim: 1990 SSE
Re: radio controls
Post by phoenix_flame220 »
Most reputable shops should be able to order the data harness for your car. In my opinion it is always best to upgrade the headunit. If you are going aftermarket, decide what deck you want, then find the correct steering wheel adaptor that either plugs into, or hardwires to the aftermarket stereo. The infrared interfaces arent as reliable or convenient. I use these.
PAC SWI-PS - covers Pioneer, Sony, Jensen, Advent, and Dual
PAC SWI-JACK - covers JVC, Alpine, Clarion, and Kenwood
PAC SWI-X - uses infrared, works with pretty much anything with an IR remote
The programming instruction are a bit tricky to figure out at first, but once you get it, its actually really straight forward.
Last edited by phoenix_flame220 on Mon Oct 18, 2010 1:26 pm, edited 2 times in total.
__/"""""\___
"-@--------@--" 1990 SSE " Black Ice " 215,456+ kms,
16" Streetwear Diablo wheels | FWI | Magnaflow cat | '94 top swap | MSD Ignition | Projector Retrofit w/ HIDs | Modded Mesh Grille | STB | Blue interior LEDs | LED 3rd brake light | Dynamat | Woodgrain delete | JVC NX-5000 nav/dvd | Infinity 1230W
http://www.cardomain.com/ride/674760/19 ... bonneville
bonnelover
Re: radio controls
i see ebay has a lot of these adapters
05 SLE
November 2010 COTM
2002BonnevilleSE
Re: radio controls
Post by 2002BonnevilleSE »
Might try here. If they have it you should ba able to install it yourself. I know they had a wiring harness for my 2002 so I could install a different head unit.
http://www.metraonline.com/defaultl.aspx
Last edited by 2002BonnevilleSE on Fri Oct 22, 2010 11:13 pm, edited 1 time in total.
Cadet Blue....Not perfect...But paid for.
K&N Air Filter and Gutted air box. 180 Thermo Cleared Corners More to come.
"Unfortunately there is one thing standing between me and that property: the rightful owners."
- Hedley Lamarr, Blazing Saddles
"One morning I shot an elephant in my pajamas. How he got in my pajamas, I don't know." Capt. Geoffrey T. Spaulding - Groucho Marx - Animal Crackers
bonnelover
Re: radio controls
thanks, i checked the site out and they have it all, will have to give them a call!!
05 SLE
November 2010 COTM
2002BonnevilleSE
Re: radio controls
Your welcome :beerchug:
2002BonnevilleSE
Re: radio controls
BTW if your stock radio has a theft device make sure the radio is turned off or when you unplug it the lock will activate and you'll need to get the code if you ever decide to put it back in. (from previous experience)
