Steering Wheel Controls for Lesabre
tz2772
Year and Trim: 1990 LeSabre
Post by tz2772 »
Original:
Removed:
New:
I've got the wheel and installed it, but I haven't yet wired it up, since I need to find a source for the wiring and other column parts to support the controls. The wheel comes from a 1992 Century limited, as GM never offered the UK3 option on the LeSabre or Electra/Park Avenue, despite offering it on the Oldsmobile and Pontiac H/C body cars of that era. I also need to clean or replace the horn pad.
I believe my stereo, being the up-level cd player for that year can receive the signals. In the FSM it shows the conenction to the serial data line on the radio harness, but labels it as "not used".
matt
1990 Buick LeSabre Limited 100k - Black Sapphire Metallic
Mods:
Strut Tower Brace, Type II Delco Ignition with MSD Coils, Delco 140 amp alternator, 89 Electra/PA CD Player, Audiovox CommanderMT XM Radio, V08 HD Cooling Radiator with Second Fan, 3/8" Transmission Cooling Lines, B&M Aux Transmission Cooler, F41 Front & Rear (Air) Struts, F41 Front & Rear Sway Bars, 96-00 Buick LeSabre/PA 16" wheels and tires, 89-91 SSE Console/Shifter, Class II Trailer Hitch and Wiring, $1000+ in Second Skin Sound Deadening Material, LeSabre T-Type Cluster, 91-92 Buick Century Steering Wheel Controls. Amsoil SSO 0W30 and Amsoil ATF.
Next: Cadillac FWD V8 Braces, F41 Springs, 1988-1991 Olds A/W/C/H -body Driver Info Center (already wired, waiting on a mount)
2003 Mercury Grand Marquis LSE 153k - Silver
Mods:
Pioneer AVIC X910BT Navi, 2010/2011 Mustang 18" Wheels, Class III Trailer Hitch and Wiring, Amsoil in Engine, Trans, and Differential. Damaged Jan 2012 - waiting on adjuster to determine fate -
Re: Steering Wheel Controls for Lesabre
Post by Jrs3800 »
Yes that HU you have is set up for steering wheel controls, and does have the little controller card... What ever they call it..
when I installed the steering wheel controls on my LE I added the internal parts and 3 or 4 wires... I know I had to tap into the Illumination, 12v switched, Ground and Data... Its a really interesting set up, and is still impressive today... Really impressive that they had the technology for it in 85-86...lol
