We have a 96 Deville (North Star), that over heats when we drive it on the streets. The car is fine on the high way, in fact we just drove it 125 miles with no issues. When driving it on the street it doesn't take very long for it to over heat. Where should I start?
Thanks in advance for all help.
1996 Deville over heating
- harofreak00
Re: 1996 Deville over heating
Are your cooling fans turning on?
- WeeBey
- Year and Trim: 95 Park Ave (S/C)
98 Bonneville SE
Yes, they are.harofreak00 wrote:Are your cooling fans turning on?
Are you losing coolant? I hate to say it, but those engines are famous for blowing headgaskets.
- WeeBey
98 Bonneville SE
It is losing coolant. There is no coolant on the dip stick, and no puddles in the drive way.
Car seems to be fine as long as it has coolant in it, but it doesn't take long for it to run out.
Sounds like headgaskets to me. A leaking HG will lose coolant into the cylinder, not into the oil. Try and take a sniff of the exhaust. Does it smell sweet?
- dpnewfie
- Posts like an LN3
- Year and Trim: 2005 GXP
That kind of fluid loss into the heads would be producing a lot of heavy steam/smoke from the tail pipes. But, it seems like the only choice as there is none in the oil and none on the ground.
2005 Bonneville GXP, 200k and SOLD!J Wikoff wrote:It has been an honor and privilage to have been serviced by you.
