Suburban idle issues
- Year and Trim: .
What controls the idle on my 95 Burb. I know it is supposed to idle up when cold, but idling at 1500 when it is 70* out is a little high. There are also times when I will come to a stop and it will idle around 1000 and slowly drop to 700 after a few seconds. It even does this when the coolant is up to temp. This is running the OBD I yet and does not have an IAT or MAF sensor, but does use a MAP sensor and TPS. The TPS is fairly new and is non-adjustable, but is reading correctly according to my Haynes manual. Does it have a second temp sensor besides the one in the left head? Is it possibly a bad MAP sensor?
Other than that, the truck runs and idles fine.
- willwren
- Retired Admin
- Year and Trim: .
Re: Suburban idle issues
On my 95, it was primarily controlled by the TPS, believe it or not. I had an idle issue like yours, and it ended up being the tps. Get a meter on that sucker.
- Year and Trim: .
I have my scan tool. I will monitor it when I take Wendy to work tonight.
- LeSabreUltra
- Posts like a Northstar
- Year and Trim: 2012 Nissan Maxima SV Premium
Hmm, I may be having a similar issue with my S10. Every now and then it'll just seem to have way too much power at idle, and will rev high. Like I'm giving it a little throttle but I'm not. Then it'll calm down after a second.
Then again, my scangauge is constantly reading the TPS value and it's always 0 when I let off the gas I think, so I dunno...
-Dan
_
_
__I n n o v a t i o n__T h a t __E x c i t e s
_
_
__I n n o v a t i o n__T h a t __E x c i t e s-
- Year and Trim: .
TPS reads fine at .70 volts and transitions fine with acceleration. I am thinking maybe a vacuum leak. My IAC is at 0% and the idle was at 700RPM in gear with no accelerator applied. Doing cold start this morning to see what it does.
TUFFBONNEVILLE
- GXP Member
- Year and Trim: 95 sle
just so you know i just picked up a 95 suburban parts truck
so if you need a computer or a part or two just let me know
tuffguyracing.com
83 regal 468 big block chevy
02 gmc k2500 6'' lift kit 35'' tall tires 148,000 miles original drive train
95 bonneville sle stock 230,000 miles original engine one trans rebuilt
95 bonneville ssei 163,123 miles rebuilt engine (mean green bonne) sold
95 chevy suburban k1500 203,000 miles wifes truck sold
01 ford f350 crew cab long bed 7.3l diesel 160,000
- Year and Trim: .
This morning it was a little cool out. Idle was at 1500 and the IAC was reading 129 and slowly came down. By the time I drove the 20 miles there, it still wanted to idle high and the IAC was reading 84.
This time it did show a code 15 for bad coolant sensor input. I did find both coolant sensors. one by the thermostat housing and the other in the left head. Tomorrow I will check to see which one is for the gauge.
- Year and Trim: .
Problem solved. I checked for vacuum leaks with carb cleaner and found a bad gasket under the EGR valve. New gasket and torqued down tight and idles a lot better.
