just take the whp and /.82 and boom! acurate to 3%
like with my car, 247whp /.82 is 301chp
neat stuff i think :D
harofreak00 wrote:If you can't afford the fuel for a premium sucking car, you shouldn't be driving it. Sell it for an N/A.
Elaborate a little?gonzo4191 wrote:
Stock I was trapping at 103. Which put me right where the Dyno-Jet was indicating. With pretty much all "bolt-on mods", I was 109. After engine work, it was in the 113'ish on average, a few higher otherwise. So I understand what you're saying, but sometimes conditions at the track, driver error, and mechanical failure contributes to the "it isn't always perfect either". Trust me, I've had several spectacular runs, only for a clutch to go south upon banging it into 3rd. Or the sh*tty hydraulics on our system, keeping me from disengaging the previous gear I was in, and not allowing me to shift it to the next cog.willwren wrote:Hate to tell you, but 20% is on a good solid rebuild for a FWD. Most cars here are probably pushing closer to 25% loss, with some over 30. That formula can't be within 3% just when you factor RWD vs FWD alone, not even taking into account the greater than 5% variability of FWD drivetrains.
If you want to narrow in on it, run the calculators based on your 1/4 mile time and use them to compare to your math here. To be honest with you though, this formula isn't likely to be any better than 5% or worse error if it's taken from a sample size of 10 or more cars on this Forum alone.
Actually, FWD is a little less. There is one less thing in a FWD car to rob power that a RWD has, a driveshaft. RWD still has more usable power when launching due to the weight transfer on the drive wheels instead of off the drive wheels. All in all with identical engines in a FWD and RWD car, the RWD car will still run a better time in the quarter due to the launch. However, the FWD car may trap a mph or two faster.yea with rwd theres less loss it seems
Based on what?!?l67poweredlss wrote:Actually, FWD is a little less. There is one less thing in a FWD car to rob power that a RWD has, a driveshaft. RWD still has more usable power when launching due to the weight transfer on the drive wheels instead of off the drive wheels. All in all with identical engines in a FWD and RWD car, the RWD car will still run a better time in the quarter due to the launch. However, the FWD car may trap a mph or two faster.yea with rwd theres less loss it seems
A guy who worked at the shop that dynoed the LSS told me this. I asked him why my numbers were high and he gave me that line. It doesn't surprise me that he is wrong. The guy was a complete moron and almost crashed my car driving it up the ramp.I'm not sure where LSS got that information.
Yeah, I never knew just how hot our trannies got until I rented a new Grand Prix once. It was 40* outside and the trans temp was 195* going easy on it. Go WOT just a couple times and it shot up to 210*. The G8 usually sits around 160* when its HOT out. The highest I ever seen it was 182* and I was driving real hard.Some of this has to do with the necessary compact design of the FWD trans to fit it into the engine bay in a transverse fashion, and some of it has to do with thermal efficiency with that much crap packed into the smaller package. Heat is the primary enemy. The viscosity of your fluid is what it's all about. FWD transmissions will generally run hotter.
