Trans fluid question
dpnewfie
Post by dpnewfie »
Going to change the trans fluid this weekend and am wondering how much fluid I should buy? Going to replace filter as well.
Also; should I run some sea foam through it before I change it? Checked the fluid today and its not that bad but it hasn't been changed for 50k. :bstooges:
Thanks all.
J Wikoff wrote:It has been an honor and privilage to have been serviced by you.
2005 Bonneville GXP, 200k and SOLD!
BlownNitroPontiac
Re: Trans fluid question
Post by BlownNitroPontiac »
I just did mine. I used (2) one gallon-sized jugs of the Dexron synthetic.
dpnewfie
Post by dpnewfie »
Awesome, thanks.
Add some seafoam trans tune now, drive it until this wknd. That will clear any crud out. :wink:
CMNTMXR57
Post by CMNTMXR57 »
Be careful with the full synthetic Dexron stuff. It it's Dexron 5, you might actually be in-store for a transmission replacement sooner rather than later. I recall, that stuff is very harsh on seals inside the trans.
Dex4 is about as far as I'd go.
2011 Camaro SS
dpnewfie
Post by dpnewfie »
Thanks. I hadn't bought the fluid yet. Going to do it on my way home today.
CMNTMXR57
Post by CMNTMXR57 »
I'd also question Dex 4 in some circumstances. It is a great fluid in it's own right. But because it's so fluid (viscous) and has great lubricity properties, it doesn't always build the necessary pressure (PSI), which is important in an automatic trans for proper lubrication, shifting, solenoid actuations, etc... In some cases, this makes the trans actually work harder, shift harder, and wear it out sooner.
I can't recall if ours is DexIII or Dex4 off the top of my head. Look in the manual. Use exactly what GM prescribes. There is no reason to outsmart them on what fluid their trans needs. Now naturally, use the best fluid that meets their specs, but if it says DexIII, use DexIII. IF Dex4, use Dex4.
2011 Camaro SS
Pretty sure all of these cars are DexIII. I'm planning on putting Amsoil in our GXP when we do it. Will probably never have to change it again.
CMNTMXR57
Post by CMNTMXR57 »
Yup, looked it up, it is DexIII. I know in late 2004, into 2005, GM did have a few transmissions that went to D4
2011 Camaro SS
