ssei running crazy rich? & chugging
2KSexsei
Post by 2KSexsei »
Vehicle is the one in the sig. It started chugging a bit last night on the way home last night. While watching the wide band and the scan gauge I saw that with the slighest application of the throttle (less than ten percent) the timing was being pulled to 9.5 degrees and the afr pegged to the richest the gauge goes (10.0). Stft were at -11.5 and -ltft were at -22. If I am very very careful With the pedal, it runs as it should. I don't know what to think of this. Any ideas or directions where to go would be very appreciated
176,000 Mi. INTENSE PCM, INTENSE 3.4" MPS, 180* T-Stat, Belden Max wires, NGK TR-55's, Homemade FWI, Speed Daddy Headers, Hockey Puck Mod, Cleared Front Corners, AEM UEGO, ProSport Elec. O.P. Gauge, ProSport Elec. Fuel Pressure Gauge, Aeroforce Scangauge, Alpine 9886
Re: ssei running crazy rich? & chugging
Check for vacuum leaks. The tee under the sc snout and also check for gas in the vacuum line to the FPR.
2KSexsei
Post by 2KSexsei »
Checked the vacuum lines with carb cleaner and while it was running pulled the line off the fpr, no gas there. :(
Archon
Post by Archon »
Check the temperature sensors to see if they think that it is really cold outside. Also, disconnect the MAF and see what the readings do.
silverws6ta
Year and Trim: 2000 - Bonneville SSEi
Post by silverws6ta »
Check O2 sensor Bank 1 Sensor 1 for slow rich/lean switching.. I had one of the newer AFS109 designs (presumably denso) and it went to the crapper --- I had one of older (rounded tip) AFS109's with with rounded tip and it cleared it right up.. MPG's went back up, and not fumes..
2000 Bonneville SSEi - GXP Wheels, GM Aluminum Gaskets, 180*, AC 41-985's, AC Delco High Performance Wires, Double 'D' I-Shaft, Hogan 3" DP and Magnaflow CAT, Intense FWI, PCM, and 3.4 MPS, GB 715, Full Synthetics, LED Brake Light Conversion, Toshiba HIR's Low/High (one owner - was my moms car) 147k 11/10
2006 Cadillac STS-V - Stealth Gray - GM Performance Cat-Back Exhaust (Borla), D3 Cadillac Intake, Wait4Me E67 Tuned PCM, GM Accessories Smoke Taillights, 3rd Brake Light, Cross Drilled Brembo Rotors, 27k 11/10
2000 Trans Am WS6 - M6, SLP Lid & K&N, SLP Y-pipe, Borla Non-Adustable Exhaust (Sold the SLP); NGK TR55's, !TB, SLP Bellow, 180*, Taylor Thundervolt 10.5mm Wires, !CAGS, Custom Tuned PCM, Full Synthetics (mine from the day it was ordered )
2008 Escalade EXT - GMPP Intake, GMPP Performance Exhaust, Sport Grille, Chrome Tow Hooks, In Channel Ventshades, Front/Rear Matching Tint - 8k 11/10
