I've cut away much of the rusted outer rocker, and have started cleaning up the inner portion. I'm wire-wheeling the really loose stuff, and will hit it with a compressed air source to blow out what I can't get with the wheel.
The plan right now is to prep and POR-15 the stuff I can see, fish around with the daubers they sell for the stuff I can't, hope enough is covered by enough coats, and then put slip-on rockers on somehow. Welding is out since there's no good metal to weld to underneath, so rivets and body adhesive will have to suffice.
Now for some carnage pictures. This is after cutting away the old panel, and starting on the cleanup. They're in no particular order.
