2000 SSEI stalls while driving longer trips on the highway.
markalters
Year and Trim: 2000 SSEI
Post by markalters »
Any ideas? It usually happens on longer trips when it has been running for a while. I have already replaced the fuel pump no help there. It will start back up but then stall again later. No codes.
1fatcat
Year and Trim: before cars
Re: 2000 SSEI stalls while driving longer trips on the highway.
Post by 1fatcat »
Crank sensor is a good possibility.
golfyeti
Every available option
Post by golfyeti »
perhaps a faulty electrical connection to the fuel pump? That was the cause of random shut offs for me. First I replaced the fuel pump but in the end it was the electrical connection that was 'hit and miss' at the connector between the fuel pump wiring harness and the two-speed control module wiring harness - right up behind the rear left wheel well.
viewtopic.php?f=18&t=17834
Mark
The Familyman's Trans-Am
Intense 3.4 MPS, Intense FWI, Intense PCM, copper NGKs TR55's, MSD wires, MSD coils, BWD ICM, MagnaFlow High Flow Cat, drilled 180 'stat, solid front mount, Monroe Max Air rear shocks, Moog rear mounts, Moog suspension bushings, cleared front corners, 190,000 miles
