motor mount diy fix?
Posted: Sat Jun 26, 2010 11:40 am
by i<3bonbons
93 ssei. the front motor mount by the pullies is shot. anyone know if its ok to fix it with washers and bushings? i dont want to break anything else, and the parts store is asking for 200+
Re: motor mount diy fix?
Posted: Sat Jun 26, 2010 6:47 pm
by repinS
http://www.rockauto.com
Find the mount under "Engine" for your car, brand is Anchor, Part #2801. Use discount code from here:
viewtopic.php?f=8&t=1677 . You should be able to get the mount to your door, in two business days, for about $70 Canadian after exchange rate, shipping, discount, and GST.
I asked NAPA and the dealer about this mount and I just about fainted when they told me the price, I think it was somewhere around or over $200 as well.
Posted: Sat Jun 26, 2010 8:44 pm
by turkeykiller
I would try to find a good used one. I got mine for 20.00 at the junk yard.
Posted: Mon Jun 28, 2010 8:35 pm
by i<3bonbons
repinS wrote:http://www.rockauto.com
http://www.pontiacbonnevilleclub.com/fo ... 19&t=19096 . You should be able to get the mount to your door, in two business days, for about $70 Canadian after exchange rate, shipping, discount, and GST.
this
Thank you.
Posted: Mon Jun 28, 2010 9:49 pm
by repinS
Be careful when you remove the mount if you haven't already. The bolts are threaded into welded nuts on the backside of the frame (you can't see them). Even once you crack them open, if they start to unthread with some resistance, STOP. I managed to break one of the horizontal welded nuts and my current mount is held on with three bolts. The stupid thing is that they were probably loose enough to pull the mount out, I just wanted a bit of extra clearance and *pop* they went.
Grease and penetrating spray will be your best friend here.
Posted: Tue Jun 29, 2010 9:35 am
by Bob Dillon
Thanks, but your link above just leads to a posting box. Could you fix it, please?
Thanks.
Posted: Tue Jun 29, 2010 4:27 pm
by repinS
Odd, I don't remember copying *THAT* URL
Fixed! Apologies.
Posted: Tue Jun 29, 2010 8:15 pm
by turkeykiller
AutoPartsFreak.com has the mount for 75$. If you want to buy from a Canadian site.
