2nd question
dcbambi2011
Year and Trim: 1992 needs new trim
2nd question
Post by dcbambi2011 »
i would really like to get my 92 se being able to out rin a mazda mx7 stick what would be my best selections
J Wikoff
Re: 2nd question
Post by J Wikoff »
What's an MX7? I see MX3, 5, and 6.
There are roller rockers available from Yella Terra, cams from Crow. A Magnaflow hi-flo cat. Chips from Hypertech and Jet. Custom tuning from SinisterPerformance/GMTuners. 160 and 180 thermostats from Hypertech and Intense. Search Rice Pipe or Intense tubing to make a CAI.
willwren
Re: 2nd question
Post by willwren »
The first thing we need to know is what V8 you installed (per your intro topic) so we can do a valid hp/weight comparison between the two cars. The performance parts we use on our V6's will most likely not work on your V8.
dcbambi2011
Re: 2nd question
i fnally got ahold of my dad and we pulled the v8 out of a cadilac northsar 2000 4.6l does that help? and mazda mx8 sorry about that my dude fat fingered the key board and i didnt mean to put the 7
ChilinMichael
Year and Trim: 2004 Volvo S60
Re: 2nd question
Post by ChilinMichael »
You've got a Cadillac Northstar in a 1992 Bonneville? I'd love to see this.
If it really is a Northstar, you aren't doing much with it. I can tell you that, they don't mod. (Well, not easily, that's for sure)
willwren
Re: 2nd question
Post by willwren »
What transmission are you using? Axles? That's important to know.
J Wikoff
Re: 2nd question
Post by J Wikoff »
I still don't know what an MX8 is. :lol:
J Wikoff wrote:What's an MX7? I see MX3, 5, and 6.
All this stuff was for a Series I 3800...
01bonneSC
Year and Trim: 05 Chevy 'Hoe
89 SkiDoo
Re: 2nd question
Post by 01bonneSC »
I dont think youll be out running an RX8, i think thats what you mean.
EDIT::: There was an RX7. What year RX8 are you talking about?
willwren
Re: 2nd question
Post by willwren »
The bottom line is that we need a ton more specifics on your drivetrain and PCM setup before we can tell you anything.
dcbambi2011
Re: 2nd question
the only thing i have changed is the engine everything else is stock on it idk what came stock for those years but today i am getting my radiator fixed the welds wore out on it or something like that
ChilinMichael
Re: 2nd question
I'd find that impossible for a 4T60 to mate to a Northstar, not to mention even IF that happened, the Northstar would tear that transmission apart rather quickly, also not to mention PCM issues and various other obstacles. I think we'll get a better idea here what you are working with if you could please take some pictures of your engine bay and then we'll be able to determine what needs to be done.
dcbambi2011
Re: 2nd question
as soon as i get it all together i will, do you think its possiable for my dad to have done somethings that i dont even know what is done to my own car how can i tell if anything has been done before i got it?
that the PCW thingy whats that? i am no mechanic i build houses not cars i honestly want a car that will carry my stuff for work and a small family tell me what i need to look at to find out whats all on my car i have only had my car for like a month
willwren
Re: 2nd question
Post by willwren »
I can tell you it's not possible your Dad put a Northstar in the car without also change the transmission, axles, and PCM (computer). That being the case, you'd likely have other issues unless he'd done it before.
Simply take a picture of your engine for us and we'll tell you what's going on under there. Or count your spark plug wires, describe your ignition coil setup (where the wires start), and any markings or words on the engine cover.
dcbambi2011
Re: 2nd question
the coils there are four of them two on each one and and on the side of the motor first coil (7,6)(4,1)(3,8)(5,2), i also says north star 32 valve v8 and how do i put pics on here i got my camera fixed
Re: 2nd question
