I bought a 1996 ssei at the end of the winter the ac doesnt work. The is no pressure at the valves ,and the clutch doesnt kick in. Where do I start. I dont have much cash at the moment. So I want to keep it cheap.
I have ac parts On my 1997 se. (parts car) Which the ac stopped working at the end of last summer.
Where do I start. By putting gas and seeing if it leaks (what phreon).
Is there a book AC FOR DUMMIESlol
Ive never touched any ac on any car so please keep it simple
Thank
air conditioning I hot where do I start
- turkeykiller
- Year and Trim: 1996 SSEi
2009 Saturn Astra XE
1999 grandprix se - Location: Granby Quebec Canada
It can be done, it will be done, it should be done, it shall be done...tomorrow
PONTIAC BONNEVILLE SSEi 1996 gutted air box 180 deg
PONTIAC BONNEVILLE SE 40th 1997 RIP(parts car)
SATURN ASTRA XE 2009
Re: air conditioning I hot where do I start
best to start with pulling vacuum on system. will remove any moisture and also tell if you have leak. post back results or questions.
- turkeykiller
ya the evapoator is leaking and a really good leak well its more like a hole. Im going to start by fixxing that
gmman wrote:best to start with pulling vacuum on system. will remove any moisture and also tell if you have leak. post back results or questions.
LeSabre in Buffalo
- Year and Trim: 2012 Eco
Fix any known leaks, fill it with dye, and run it. Then get a blacklight and check where the dye leaked out.
- turkeykiller
changed the evaporator and then I put 2 bottles of duracool, everything is working great.
Was there anything else that I should do
One thing for sure its pretty cool in there. Lets hope it will work for the whole summer(i m praying)
if you pulled a vacuum and determined that you don't have other leaks, you are probably ok. changing the accumulator is also a recommended practice when you have had system open but if you are cooling ok it would appear you got most of moisture out of system.
sounds like you did a great job!
- turkeykiller
let hope that its still working today
gmman wrote:if you pulled a vacuum and determined that you don't have other leaks, you are probably ok. changing the accumulator is also a recommended practice when you have had system open but if you are cooling ok it would appear you got most of moisture out of system.
- turkeykiller
everything is still cool
