I just bought a 95 bonne sse about 2 weeks ago and the power locks don't work at all i bought a key fob off eBay and programmed it when i push the lock or unlock button on it I hear a click in the door but there is no movement in the sliders.
The wierd thing is when I went out to go to work today I opened the door and my alarm started goin off (didn't know it worked) for no apparent reason so i get my key fob and try to use it to shut the alarm off..... didn't work eventually i just started the car and waited for it to go off. Is there a problem with Buick key fobs controlling Pontiac alarms (place sent me the wrong brand) or is something else the problem?
Power Locks and alarm
Marshall2469
- SE Member
- Year and Trim: 95 Bonneville SSE
- Year and Trim: .
Re: Power Locks and alarm
Sounds like either they need lubricated or the actuators are bad.
if you just hear a click from under the dash, it might be the door lock fuse. that's underneath the passenger side hush panel.
Of course, there's a reason the fuse blew, and it'll probably blow again, unless you find that reason and fix it.
