Does this look sufficient, or does it need more work, or did I already mess it up? If more pics are needed, let me know what area and I will post it. Also, should I plug the silencer ports? I would probably have them welded if I did. Thoughts on this?
doesnt look too bad from the pics. I think you may want more of a 45* angle on the outlet. And may be able to smoothe out those rough spots on the inlet.
but, is it necessary to port back by the rotor bearings?
and imo, I wouldnt touch the silencing ports. Not worth the trouble. performance gain to the cost of having someone tig weld them shut is marginal at best. And the noise would be rather much. If you want to hear more whine, put in a FWI if you dont have one yet, belive me, that is more than sufficient.
Unless you want it to SCREAM, leave the silencers. You want that fiero at least a little sleeper, lol.
Bye Bye: RIP sandrock
I think that looks pretty good, really. You got the most important part, being the excessive roughness of the inlet.
WHITE WHINE - 1992 SSE Supercharged 236.26 ci (.040 Over) 15.090 at 90.2 MPH on old engine w/ slipping trans & melted O2 sensor - Gen 3 M62 and matching TB, Gen 2 Pully, Zillamotorsports Ported LIM, YT 1.72 Roller Rockers, SII FPR & Injectors, Hypertech Thermomaster chip w/ 160 Thermo, TransGo Shift Kit, Infinity/Pioneer Speakers & a 10" Alpine Type R Sub, all the watts, 140 amp Alternator, Ricepipe CAI w/ heatshield, Pilot Angel Eye Foglights, Clear Corners, '02 17" Chrome Bent 5's, Magnaflow F-Body Muffler and Hi-flo Cat, Ceramic Coated Ported Exhaust Manifolds, Fan Override, Monroe Reflex struts, red calipers 2009 G8 GT - Sport Red Metallic, loaded, SOLO Axlebacks, Rotofab Intake, Tuned, autodim mirror, removed intake manifold cover, HSV GTS triple gauge pod, two tone red-hot shifter and HSV SuperSport steering wheel, GXP rear sway bar and diffuser, 3.45 diff and various Camaro suspension bits, LED Taillights
Wes wrote:but, is it necessary to port back by the rotor bearings?
check out bills site for what I mean about the 45* angle on the outlet.
1fatcat wrote:
You mean this porting? That is the inlet of the blower, looking at it from the rotor side.
So I should open up the outlet more?
00Beast wrote:Unless you want it to SCREAM, leave the silencers. You want that fiero at least a little sleeper, lol.
Ok, I'll leave them. Wasn't too thrilled about welding them for noise, but if there isn't a power gain I'll leave em.
J Wikoff wrote:I think that looks pretty good, really. You got the most important part, being the excessive roughness of the inlet.
I was hoping someone would say that. I do not want to do anymore to the inlet because it really sucks to get in there. I know it isn't perfect, but good enough for a stock cam/heads engine for cripe sakes
Wondering about the outlet though, that is easy to work on. Should I open it more? I thought you start loosing outlet velocity if you open it too much?
It's been a while since I heard the term "S-porting", but it involved enlarging the top point of the outlet opening in your last pic. Maybe it doesn't apply well to M90's. Might warrant some googling...
Don't enlarge the outlet, chamfer it to prevent 90° turns of the boost charge to exit. A 45° chamfer on the inside is a must, a smaller one on the outside edge of the outlet might be a help. Then polish it to a mirror shine. This will help prevent deposits from building up (which can cause hot spots).
Your outlet pic is blurry. Can you post a better one of the inside and outside of it? The inlet looks fine, that's smooth enough. It's only necessary to knock down the high spots left from the casting process.
