L67 Rebuild, Which pistons are you guys using?
Posted: Tue May 11, 2010 5:36 pm
by 2KSexsei
I am currently rebuilding a L67 out of a 2000 SSEi, I see in signatures different pistons are being used, but can't seem to find where to buy? I am boring the engine .030 over and would like to know what you guys think I should put in it. I will probably do a cam, rockers, and maybe an IC in the future. Thanks for the help.
Re: L67 Rebuild, Which pistons are you guys using?
Posted: Tue May 11, 2010 6:55 pm
by dangrus4060
I used the L32 Powdered Metal Rods when I rebuilt my L67 last year. Working great!
Posted: Tue May 11, 2010 7:45 pm
by 2KSexsei
BTW, the engine is going is a front engine alcohol 1/8 mile rail
Posted: Tue May 11, 2010 10:46 pm
Here's Intense's Hardcore engine page, they sell Diamond pistons. Not sure on the price, though. Over $100 each, ouch.
http://www.intense-racing.com/Merchant2 ... y_Code=PBF
How many HP are being planned? That will ultimately decide what your plans are. Like the old saying goes, "How fast you can go is directly proportional to how deep your wallet is."
Posted: Tue May 11, 2010 11:44 pm
by 2000Silverbullet
Go forged.
They are more expensive but are much stronger than powdered. The OEM pistons are powdered and they will break under high loads and cycles. Powdered are better than cast but forged are the best.
Posted: Wed May 12, 2010 8:53 am
by willwren
Paul, stock L67 pistons are forged, not powdered. S3 rods are powdered, S2 timing gears are powdered, but not the pistons.
Posted: Wed May 12, 2010 4:59 pm
by 2KSexsei
I am not going for a ton of power, my main goal is consistency. I am not really worried about E.T. or insane trap speeds. I am not looking to build a high dollar balls out engine, just looking for somewhere to start. I know the engine will be way way low compression for alcohol, but i don't want to have to worry about smashing valves either..
Posted: Wed May 12, 2010 5:10 pm
by 2KSexsei
00Beast, The wallet isn't very deep at the time being, I modeled up the chassis for the rail using solidworks and have sent the Material list for the chromoly to a couple race shops around, and have located a transmission I can borrow for next summer. So, I guess I will see where I am at for an engine budget at that point. A buddy and I are currently in the process of writing up a prgram for the CNC lathe to notch the pipes(because we are lazy like that).
Posted: Wed May 12, 2010 8:18 pm
by 2000Silverbullet
Funny, I read somewhere that they were.
That and the thin land area above the top ring contribute to the breaking around the top perimeter like yours and many others have.
So not only metallurgy but actual design of the piston makes a big difference.
Posted: Thu May 13, 2010 1:31 pm
by 2KSexsei
Not to change the topic here, but I just bought a complete L67 with 80k on it, the shop I bought it from says it has a bad bottom end. The blower was bought from GM less than 5K ago. I paid $300 for it.. Think I did good? or is that high?
Posted: Thu May 13, 2010 2:09 pm
Not a bad deal, considering a new S/C is expensive.
Posted: Thu May 13, 2010 5:59 pm
by 2KSexsei
About what does the blower run if a guy were to go to the dealership to get it?
Posted: Thu May 13, 2010 6:01 pm
by Wes
I asked the dealership out of curioutity one time......its ridiculous. It was in the $1500 range. direct from magnuson i believe the guy said.
Posted: Fri May 14, 2010 4:33 pm
by 2KSexsei
Wow, Thats alot of cash.
Posted: Sun May 23, 2010 2:58 am
by 01bonneSC
Just curious as to why you are running a 6 in a rail car? I know its different and all that.
Posted: Fri Jun 11, 2010 6:50 pm
by 2KSexsei
First off, just to be the oddball. Second, these engines are extremely reliable, and in the world where being dead on run after run is all that matters.. It's great.
Posted: Fri Jun 11, 2010 7:08 pm
by 99bonnieSE
i'm kinda interested in this. Post some pics of when she's in!
Posted: Sat Jun 12, 2010 4:44 pm
by 2KSexsei
It is going to be awhile before I get anywhere on it. I am being sidetracked and spending my free time working on a program to produce an intercooler plate similar to the one the W body store sells..
