Removing SC Nose Drive
All questions and problems regarding Superchargers, Turbos, NOS, ZEX, intercoolers, water injection, etc.
rustyoldcars
Year and Trim: 1995 Bonneville SSEI
Post by rustyoldcars »
95 SSEI 132,000 miles needs SC coupler. (I am sure) Can someone talk me through removing the nose drive with the SC attached to engine? Does the bracket\mount for the ps and alt need to be removed? Thanks, Harry
willwren
Re: Removing SC Nose Drive
Post by willwren »
You have to remove the supercharger entirely. Starting 96 with the larger Eaton M90, you don't.
You'll need a new SC gasket, anearobic sealant, oil, coupler, and two yellow o-rings for the coolant flow between the SC and LIM. It's a good opportunity to remove the TB and clean it (with sensors removed).
Wes
Post by Wes »
the belt bracket will be in the way. its really not worth doing it that way i believe. For a series I, you should remove the s/c from the intake to remove the nose drive.
yourgrandma wrote:High
rustyoldcars
Thanks so much. I really was not excited about removing all that bracket stuff again. I replaced the water pump about three weeks ago. That was no "walk in the park." I'll start gathering the supplies, thanks for the list of parts and....Harry
rustyoldcars
95 SSEI Removing Supercharger
So I don't blunder myself into a corner, are there any instructions on removal and replacement of the supercharger. I would feel more confident with the old Step1, Step 2, Step 3, in front of me as I do the work. I did find a diagram of the vacuum lines routing but that was all I could find.
J Wikoff
Re: 95 SSEI Removing Supercharger
Post by J Wikoff »
I'm a bit busy at work. If noone gets one up today, I can do one later today.
SSEi95
Site Owner/Webmaster
'01 Sierra C3
Post by SSEi95 »
http://3800supercharger.net/
Here some information on the supercharger. I thought there was something around here somewhere that had a full write up. I'll look some more later today for it.
willwren
Post by willwren »
(topics merged)
rustyoldcars
Thanks for the links..I had seen them while I was looking around for info on SC R & R. Nothing there seemed to show the removal.
