out with the old in with the new.. bye bye 4 15'' l7's
88bonnsse
Year and Trim: 1988 sse - 80,000 on the clock and my first car...
1995 se wit da sle package- 120,000 on the clock and ticking stronger then ever...
Post by 88bonnsse »
i am doing a serious upgrade. im going from 4 15'' l7'S and 2 kicker zx2500.1 amps and im upgrading to
3 18'' re audio sx18 subs and 3 kicker zx2500.1 amps.. its going to be insane in my bonneville. the air pressure will be sick from 3 18's in a family sedan built into a wall in the back seat area thru the trunk..
the owner of the company told me the more power i feed these bad boys the more happy they will be ...i sat back and smiled............
99bonnieSE
Year and Trim: 1994 K1500 Silverado
Re: out with the old in with the new.. bye bye 4 15'' l7's
Post by 99bonnieSE »
:eek!: :eek!: :eek!: :eek!: :eek!:
That's AMAZING!
A twin to the Fi BTL. they take the same exact re-cone if im not mistaken.
You will not be dissapointed.
It's been a very long time, but, I am still around!
01bonne
Year and Trim: 2001 SLE
Post by 01bonne »
You sir are a true bass head. I can't wait to see you set up, are you building your box like you did before and what are you doing with the l7's
Night Hawk, The 4 door coupe
2 12" Pioneer Premiers in a vented box $350.00
2200 watt comp mono amp $200.00
7 inch Power Akoustic touchscreen 400.00
Setting off countless car alarms and making my passengers ears bleed... PRICELESS
Bugsi " then you could achieve that with fewer subs and still have (some) trunk space left over to carry groceries/body parts/etc"
