What would you do?
- willwren
- Retired Admin
- Year and Trim: .
What would you do?
Keep in mind:
Zilla: Broken pretty bad, won't move until early Feb at the earliest, has summer performance tires.
SLEeper: Pretty bad front hubs, BAD rear brakes, and really good all-seasons.
Lisa's Fusion: Crappy tires.
Scenario: Gotta go to Eastern Oregon over the pass this weekend. Do I drive the Fusion (Lisa's not comfortable considering the mountain pass and the weather in driving it herself), or do I put the SLEeper's wheels on the Fusion? SLEeper is 5x115, Fusion is 5x114.3?
Or do we just take the SLEeper as is?
(and if we swap, who wants pics?)
Re: What would you do?
Bill, I've seen a completely toasted front bearing, and the truck still drove. The bearing came out in two pieces.
How bad are the brakes? Something you could fix before the weekend? Or is it driveable as-is?
- repinS
- Moderator
- Year and Trim: 09 G8 GT
How many miles is that? I hear about lots of people putting 5x114.3 on 5x115, but never the other way around. That could mean a lot.
As for rentals... Hertz up here rents out AWD SEL V6 2010 Fusions... may be worth considering. I did when rebuilding the trans on the 95.
- willwren
- Retired Admin
- Year and Trim: .
Budget doesn't allow for a rental.
Rear brakes on the SLE are non-existent. Rear hubs are frozen to the drums with rust (all original, recent discovery). If it wasn't that bad, I could swap rear brakes tonight (Zilla's are only a year old) , but it's out of the question now. We leave in the morning.
- repinS
- Moderator
If that's the case, I'd try mounting the SLE's wheels on the Fusion, carefully seating the wheels and torquing (goes without saying)... and barring any fitment/rubbing issues, pussyfoot it for this trip.
Any speedometer error to be worried about?
http://www.miata.net/garage/tirecalc.html
PRD2BDF
- Year and Trim: 2005 Saab 9-3 Arc
Buy new tires that aren't crappy for the Fusion, that is what I would do.
That way, Lisa won't hurt herself when she drives by herself in the future.
- willwren
- Retired Admin
- Year and Trim: .
Cody, we don't have the budget right now for tires if we don't have the budget (christmas recovery mode) for a rental. We don't have it for tires either, and the tire shop is CLOSED for the evening anyway, and we're leaving early in the morning.
- 2000Silverbullet
- Retired Gearhead
I would take the Sleeper.
The hubs and brakes will last for this trip.
You could chance torquing the wheels on good and taking a wrench along to retorque for the return run.
- BonneMe
Rear brakes don't do *shoot*, and if you're losing it, then they just make you come around half the time in a bonneville anyways. Try a couple hard backup stops and see if the adjusters kick in? Fusion has some good TC/ESP i bet. But it can only do so much with the grip it's given, how bad are they really? Are you considering chains at all? We needed some at Mt Hood skiing once, but that's not nearly as traveled.
We've driven that pass in a snowstorm in the ol' transport, it did alright as far as I remember. They usually keep it clear enough IIRC.
As I look at it, would you rather have the Fusion and have to drive slower/more careful, or the Sleeper and risk (prob not big, but there) breaking down in winter?
petraman
- Year and Trim: .
2013 Audi A4 6MT - Location: ............ Granville, Ohio/Erie, PA *WCBF '08 SURVIVOR* *NEBF '07 SURVIVOR*
Does that car audio store that we got the tint discount at install wheels? Because they might have an adapter if they do... Honestly, though, would it really hurt to run those wheels on the Fusion for just one trip?
Oh, and FYI, the Fusions do use a thinner sidewall (205 vs. 225), so there will be some discrepancy with the speedo
- bill buttermore
- Retired Gearhead
- Year and Trim: 98 Caravan is the daily driver 215K
If the wheels will swap with no problems, I would go that way.
1998 3.8 Dodge Caravan 214K
2000 3.3 Dodge Caravan 175K
- onesweetride
- SE Member
- Year and Trim: 97 SE.w/ 96 SE parts
Borrow a car!
1fatcat
- Posts like an L67
- Year and Trim: before cars
Cancel the trip, return your bricks and mortor, buy new tires.
- RJolly87
How crappy are crappy tires? Tread down low? Dryrot?
Honestly, I would be inclined to just take the fusion, because the wheel swap is an unknown, and possibly a hazard, so are bad brakes, and I wouldnt want a hub to fail catastrophically. You may wish to rotate tires on the fusion as you see fit, put the best ones where you feel they will be their best, and just be prepared.
- SSEimatt93
- Senior Moderator
- Year and Trim: 2016 Scat pack
I would take the SLEeper.
3.09's 8 Speed Auto
04 GTP
3.09's 8 Speed Auto
04 GTP
bonnevillain
- Year and Trim: 2002 SLE
Take the fusion for sure. especially if it's AWD. swap the tires too.
- willwren
- Retired Admin
- Year and Trim: .
The $75 the bricks and mortar cost were paid by Home Depot gift cards from work, common practice along with Starbucks, book store cards, best buy certificates, etc.1fatcat wrote:Cancel the trip, return your bricks and mortor, buy new tires.
Fusion is not AWD, and the tires are crappy in terms of grip, not lack of tread. They're factory delivered tires that came on the car, and they just flat suck in snow and ice, or when it's wet and cold.
Boss455
- GXP Member
- Year and Trim: 1999 Buick Regal GS
Take SLEper. She'll make it I think. She didn't drive too bad the last time I had her out on the interstate at WCBF '09.
1999 Buick Regal GS
1992 Pontiac Grand Prix 3.1 (the Backup)
2001 Chevy Venture (aka Rosie) Wife's Ride
1994 Pontiac Bonneville SSEi "Black Betty" NOW PACKIN' 2.5" OF FUN! (retired to the junkyard up above)
