1995 SSEi ABS Issue
ktownSSEiguy
Year and Trim: 1995 Black and Gold SSEI with 87,000 actual miles
1995 SSEi ABS Issue
Post by ktownSSEiguy »
Hi folks:
Got a 95 SSEi w/ 90K miles on her. This has happened twice. I can go into extensive detail, and will be glad to if someone can steer me in the right direction.
I always run Traction Control, Performance Shift, and Performance Ride.
On 2 different occasions, I have started her up, everything is as it should be, drive 2-5 miles (I'm on a limited income), and come back out of the pharmacy or grocery store, fire her up again, and my ABS and Traction Off lights come on, and I get about 1/2" of hard pedal. I did have a rear brake job done (watched him, good work and good parts) about 2 weeks ago. Had a soft pedal, so I took her back for a rebleed. On the way down there, I stopped at a parmacy to get some refills, came out and everything went south. Extremely hard pedal, moaning from under the hood. Got back to the shop, and the tech said he had never seen that before. He proceeded to pull the air box and un-plug the 2-row Packard/Delphi connector (snapping off the locking arm in the process) leading to the ABS pump, and of course it quit.
While he was making a few calls, I reached down and looked at the connector itself and the contacts were all seated properly and no signs of corrosion visible.
I plugged the pump back in-no sound. He did a rebleed, lots of air in the rears, (still got more travel than I want), front pads are really good, but ceramic soon, I hope. And when I do go ceramic, are drilled/slotted rotors worth the money? That's another issue altoghter.
What in the name of Richard Pryor is going on?
Sorry to be so long.
I'm still a Newbie-got some nice photos of my baby I want to post.
Thanks so much for any and all input-if'f I'm stupid, that's no problem. any and all input will be read, digested, and greatly appreciated. My cat and my car are all I have, and I'm tired of losing sleep and weight over this "ghost".
Y'all got some really nice rides out there. Keep it up.
And GM ditches Pontiac? Don't get me started!
Happy Thanksgiving to all. As bad as it is, it can always be worse, speaking from a Cancer survivor.
Re: 1995 SSEi ABS Issue
Sounds like your ABS pump is goofy.
As far as drilled rotors, don't get them. Slots are good, but drilled rotors can crack around the holes. I highly recommend ceramic pads. I know Auto Value has some slotted rotors that are pretty good. olblueeyesbonne and Archon both have them, IIRC.
J Wikoff
Post by J Wikoff »
Cheap drilled rotors tend to crack. Rotors where the hole is cast in tend to last longer. I've got powerslot slotted rotors and like them.
So after plugging the ABS back in, the only problem is pedal travel?
ktownSSEiguy
Yes, everything returned to normal except for, in my opinion, excessive pedal travel. I have no bleed-down at a stop light, so I don't think that the master cylinder has a problem. The tech didn't have the equipment to pull the codes on a 1995, so he disconnected the battery for 15 minutes to clear them. I guess the next time it happens, I'll go straight to the dealership. This is my first GM, first car with ABS, so I am lost!
J Wikoff
Post by J Wikoff »
If it is the pump going, which it sounds like it is (I could be wrong though), you should be able to unplug it when it does it again. If it were to do something wierd, you could lose braking at the wrong time.
ktownSSEiguy
I agree, to a certain point. I have years of experience in Commercial, Industrial, and Military electronics, and this shows all the classic signs of a relay "sticking". But I don't know in this case. Do you agree with the scenario of waiting for it to happen again, and going straight to the dealer to pull the codes?
BTW-Thanks so very much for trying to help me. I'm on a fixed income, and I feel welcome to this site, and for all the responses I have gotten from you and your Members.
Thanks Guys!
If anyone thinks of anything else, pleases let me know.
Could this be a symptom of a bad power brake booster failure?
J Wikoff
Post by J Wikoff »
I think it should store codes so you could get it scanned before it happens again. But I'm not positive though. I typically wait till something repeats itself to diagnose, but that's just me procrastinating.
Post by Jrs3800 »
You will need to wait for the EBTCM to set a code and then have it pulled.. You may have an issue with a wheel speed sensor or possibly an inlet / outlet pressure sensor.. any of these can piss off the EBTCM...
Thats the best advice I have to offer at the moment.. :wink:
ktownSSEiguy
My sentiments exactly. 'If it ain't broke, don't fix it".
Haven't thought about the wheel speed sensors, or I/O pressure, because I didn't realize the impact on ABS. Think I'll take her by the Dealership (got a buddy down there, but I can't get in touch with him because he works all the time), and be willing to pay 1/2 hour labor to pull the codes.
Really want to get her right. She's the last car I'll own (unless I go Ferrari Heaven), and I love the car. I went from a 1989 Ford Probe LX with 190K miles, no air bad CV joints and a leaking head gasket to my 1995 SSEi with 90k miles. Had her 3 years, and she's still smarter than I am. Still trying to get photos posted.
Thanks again for the help, ideas and support you guys give out.
This is 1 club I like!
Post by Jrs3800 »
No problem... Happy to help where we can..
I bought My first Bonneville about 12 years ago... I had the intent to keep it for one year... I still have that very car.. Florida Sun Faded... I still love driving that car... I bought a 91 as a 2nd car... Later a 95 Transport came my way... Then I bought an 03 SLE Bonneville..
At our forum meets we have had everything from Chevy trucks to Buicks... Never know what will show up... we have even had fords... I think every meet is not complete unless there is a Ford someplace...lol
Glad to have you here, and do post a few Pics :wink:
If you get the car scanned, let us know what the Codes were.. Its always interesting to know the cause of a problem.. :wink:
ktownSSEiguy
Again, guys, thanks so much for the input and direction. I took her out today , and she was the perfect Lady. Scary. Even though the front pads are really good, I'm thinking about going ahead with the slotted rotors and ceramic pads at either the Dealership or a different brake shop, and see what happens. My local dealer lets me buy my own parts, and they do the job and guarantee the labor. Hey, I take 5-1/2 quarts of Mobil 1 and a filter down there for an oil change; they do everything, change oil and filter, check and top off ALL fluids, and charge me $10.40. Hell, I can't jack the car up and get all the stuff out and change and dispose of the used oil for $10.40 in time alone!
I still love her, but I do want a Saleen or Roush before I die! Just one of my Genie Bottle wishes! No diss on the Bonnie; just always been a Ford guy-until I get in the Bonnie. The Bonnie is a sleeper; most people don't know what the car is, where if you're driving something that says Saleen or Roush on it, nobody wants to play.
If I don't hear anything back from anyone before Thanksgiving, I wish you all a very happy, memorable, blessed Thanksgiving. Thanks again. You guys are great. I need all the friends I can get!
