supercharged lesabre?
rogers9c1
Year and Trim: 1999 buick park ave 1996 chevy caprice 9c1
Post by rogers9c1 »
its always been on my mind to drop a supercharged 3.8 engine and tranny into my 1998 lesabre, what else would I need to make this happen? is this a unrealistic idea even with a parts car? Thanks in advance if this is posted in the wrong area sorry please move.
l67se
Year and Trim: 97 SE w/L67
Re: supercharged lesabre?
Post by l67se »
If I can put one in this,
you can put one in a Lesabre
alec_b
Year and Trim: 1996 SSEi, Bright White, Medium Teal, 197k
Post by alec_b »
That is awesome! I love those body style cutlass supreme's. Jealous...
Mods: Clear corners, gutted airbox, Alpine CDA-9886. Plans: 4x SensaTracs, high-flow, FM 80, 3.5 pulley, and for gods sake some good rubber.
wake
Post by wake »
with a PCM a wiring harness and a couple other things its completely possible..and it should fit with no problems...
good luck :)
You'll need the L67 wiring harness for a bonneville, a complete engine, PCM, and probably have a little custom wiring to do. It's basically a glorified engine swap, since the bonneville, which is also on the H-platform, came with an engine swap. The hardest part will be wiring, and that shouldn't be terrible.
LeSabre in Buffalo
Year and Trim: 2012 Eco
Post by LeSabre in Buffalo »
I'd make sure the rest of the car is up to snuff before doing an engine swap. Living in the salty north really sucks.
rogers9c1
Post by rogers9c1 »
Oh for sure and at this stage of it all this is only a dream, I still have a 96 caprice that needs ALOT of work before I could get up enough money to do this swap, but I still want to know whats involved with this swap, Would I need a new fuel pump, what kinda wiring modification's would have to be done?
Tricked-T
Year and Trim: 1988 & 89 Buick Lesabre T-types
Post by Tricked-T »
By the way you can use a SSE or SE harness and get a kit from intense to make it work with a L67. Thats is what I am doing because I was unable to find a SSEi after a year. That swap would be pretty straight forward. I wonder if you could get away with not switching the harness out and just switching PCMs and adding the connecting harness I was speaking of, but that is me just word vomiting so I wouldn't put to much stock in it. Kind of suprised they never put a L67 in the lesabre seeing the PA could get it, the Olds, and the Bonneville, etc...
sandrock
Post by sandrock »
All he needs is that wiring to go from the PCM to the BCS...and have the PCM reflashed for an L67.
Tricked-T
Post by Tricked-T »
Pretty much what I was thinking. Would be a pretty easy swap I would assume but I could be wrong.
rogers9c1
Post by rogers9c1 »
What about things like the fuel pump? and would I need the sub frame from the SC car or any suspension parts?
So let me get this right I need a s\c engine with a hd transmission full engine harness and the harness that goes from the PCM to the BCM? any pics of this harness, and will my l36 axles go to the hd trans? I just want a realistic idea of whats needed to do this swap.
sandrock
Post by sandrock »
S2s used a dual-speed fuel pump. Not necessary IMO...so long as the fuel pressure is able to keep up with the injectors. You can swap in an L67 pump and it will run the full-speed all the time.
You should either swap in a full FE2 suspension, or order F41 spec springs. Same with the sways, front and rear, and urethane endlinks and bushings would help.
You need the engine and trans. The full engine harness you don't need....just the harness bit that comes from the PCM to the BCS. You do not need the PCM either...just reuse your PCM, send it to someone to have it turned into an L67 PCM. L36 axles will not fit the HD trans.
Only some S2 L67's used a dual speed pump. Not all.
