Good 3.8 info
alec_b
Year and Trim: 1996 SSEi, Bright White, Medium Teal, 197k
Good 3.8 info
Post by alec_b »
Sorry if this has been posted before, but this site has a great article on rebuilding the 3800 series engines, with pictures and descriptions of the differences over the years.
http://www.enginebuildermag.com/Article ... ngine.aspx
Just thought I'd share in case no one else had yet.
Mods: Clear corners, gutted airbox, Alpine CDA-9886. Plans: 4x SensaTracs, high-flow, FM 80, 3.5 pulley, and for gods sake some good rubber.
Re: Good 3.8 info
Wow, excellent info. Techinfo worthy.
SSEi95
Site Owner/Webmaster
'01 Sierra C3
Re: Good 3.8 info
Post by SSEi95 »
I've seen that site before a long time ago. Definitely good info on there.
Re: Good 3.8 info
Post by Jrs3800 »
Yep saw that a long time ago.. It is great info.. Sheds a lot of light on all of the 3800's I have..
1995 was an odd year for the 3800...LOL
rogers9c1
Year and Trim: 1999 buick park ave 1996 chevy caprice 9c1
Re: Good 3.8 info
Post by rogers9c1 »
Thanks for the post, never seen this info before this should be in the Techinfo FORSURE.
Whitecrystal1
Year and Trim: 10 Silverado
Re: Good 3.8 info
Post by Whitecrystal1 »
Jrs3800 wrote:Yep saw that a long time ago.. It is great info.. Sheds a lot of light on all of the 3800's I have..
Odd maybe but one of the best lol :wink:
2002 Buick Lesabre Custom L36 Titanium Blue Metallic/Medium Gray Cloth
2004 Buick Lesabre Custom L36 White/Graphite Gray Cloth
2015 SS Roof, Spare & 6M 6.2L LS3 415HP/415TQ SLIHRM/Jet Black Leather-Red Stitching
2010 Silverado LTZ Crew 4x4 6.2L L9H 417HP/403TQ NHT Black Granite Metallic/Ebony Leather
2013 Enclave Premium AWD 3.6L LLT White Diamond Tricoat/Cocoa Leather
2001 Wellcraft Martinique 2400 Merc 5.7L BIII 327hrs
1995 Bonneville SSE L36 Dark Polo Green Metallic **R.I.P. 4/28/10 236,400 miles**
Re: Good 3.8 info
Post by Jrs3800 »
The engine that came out of my van was freakish... It was the old series I L27... First time I changed the oil i was confused.. It looked like a series II oil pan... Hmmmmm... Pulled the Drain plug and what do you know it was a series II drain plug... In research i found that the Vibration dampener for the 95 L27 was specific to 95... Thought that was odd.. Found the motor to be able to run through the revs quick... Engine didn't feel like it ran as heavy as the older L27's... I was perplexed for a while.. Then noticed this motor was listed with a 2170 or possible 743 crank.. Turns out if you have a 95 L27 there is a very good chance you have the light weight 2170 crank.. When I saw the article it was the last stitch of proof I needed..
Its just really interesting what GM did to be able to use the series I Blocks and build the series II blocks using quite a few of the same parts.. Making the 95 L 27 a freak year motor... :twisted:
SAMzGXP
Re: Good 3.8 info
Post by SAMzGXP »
good post, lots of info
never seen it before
Cardomain link
Fully tinted, 5000K HID hi/lo & fogs, LED conversion (interior/red rear signals/reverse light/license plate/trunk/sun visor/glove box/switch backs), turn signal mirrors, JVC KW-NT3 Navi & BT, KV-CM1 Camera, 2x JL 13TW5, JL G-Max, black & chrome emblem, 20" black & red, clear corners, center tail light up, half tinted tail lights, cross drilled rotors, Hawk ceramic pads, and more..
Black GXP. One of a kind. RIP.
G35 Coupe 6MT. Stockishhh
spoiledred94
Re: Good 3.8 info
Post by spoiledred94 »
Great read. No doubt some invaluable information for series 2 and 3 motors. Not much info for pre 95 series 1's though. 95's and 94's were both transition platforms.
"One of the most significant V6 pushrod engines ever"
I don't know if that's true or not, but ok.
:P
great car. Wrecked
Burnt Bonny.
