scan tool asks if car has IPC
Posted: Sun Nov 08, 2009 9:30 pm
by pmicaza
hi,
my scan tool asks if my 97 SSEi has IPC.
What is IPC and how do i determine if the car has it?
tia,
peter
Re: scan tool asks if car has IPC
Posted: Mon Nov 09, 2009 1:31 am
by myfirstbonnie
What model and brand of scan tool are you using? Do you have a manual for it? I have not heard of that.
Posted: Mon Nov 09, 2009 1:55 am
by Archon
The only IPC that I can think of off hand is the instrument panel cluster.
Posted: Mon Nov 09, 2009 7:08 am
by londonontman
Archon is correct
Posted: Mon Nov 09, 2009 9:22 am
by pmicaza
myfirstbonnie wrote:What model and brand of scan tool are you using? Do you have a manual for it? I have not heard of that.
i have a n
actron AutoScanner Plus cp9180
any idea why the scanner cares about the InstrumentPanelCluster?
seems sotra odd?!?!
peter
Posted: Mon Nov 09, 2009 11:59 am
by Archon
I'm not sure that is what it is asking. If it is, it could be because some data passes through the instrument panel cluster. That's just a guess.
Posted: Mon Nov 09, 2009 12:21 pm
by myfirstbonnie
http://www.actron.com/publish/2007/01/1 ... _16318.pdf
PDF file for the manual. On page 97, the IPC is as Archon stated is for instrument panel cluster. I did not see it mentioned elsewhere, but you might call the tech assist or use the online assistance and ask them.
Posted: Mon Nov 09, 2009 7:33 pm
by alec_b
My snap-on modis used to ask ALMOST the same question about some GM cars, except it would ask if it had a digital odometer. I'll bet that's what they mean by IPC. If you've got a digital odo, then hit yes, otherwise no. Try that.
Either way, it won't have any effect on the way it scans for PCM codes.
Posted: Wed Nov 18, 2009 1:04 pm
by pmicaza
after several msg's to acton i am told that yes IPC is instrurment Panel Cluster...it is later called DIC or driver info center.
i dont know why the scanner cares.
hth,
peter
