will not shift onto overdrive
byvank
Year and Trim: 1991 Pontiac Bonnevile
Post by byvank »
I have a 91 Bonne we bough from a salvage yard .It sat for 2 years. It will not shift into overdrive or lockup.what should I do.The oil
looks clean and at the proper level on dipstick. The engine will not warm up so need a new 195 t stat. :) :banana:
alec_b
Year and Trim: 1996 SSEi, Bright White, Medium Teal, 197k
Re: will not shift onto overdrive
Post by alec_b »
If the engine won't warm up it won't go into lockup. Get the operating temperature corrected first, then check the adjustment of your throttle valve cable. If all that checks out you may have a more serious issue.
Mods: Clear corners, gutted airbox, Alpine CDA-9886. Plans: 4x SensaTracs, high-flow, FM 80, 3.5 pulley, and for gods sake some good rubber.
