Rear Struts Automatic Air Leveling...Blown Out Don't Work...
nunesjeff
Year and Trim: 92' SSE 83' F350 460 Dully 61' Willys Wagon
Post by nunesjeff »
My Ride Is Bouncy!!! The Rear Struts Are Toast... Are They Hard To Replace? Also I Probed The Air Compressor To Come On And Can Hear Air Leaking From Both Sides... But The Air Comp Will Not Come On Or With Switch On With The Inflatior.... And Is It Able To Air Up Tires... What Can I DO To Use It Or Does It Not Work That Way... If The System Is Garbage Can I Get A Set Of Regaular Struts....? Such A Fancy Ride With Lots Of This And That Will The Work Ever End??? LOL
~*Field Mouse*~ Lebanon, Oregon (92 Bonneville SSE) (Dark Polo Metallic Green) "Green Jelly" (Daily Driver) Silver Star Lows, Highs And Fogs What A Bright Idea...
Ol' Timer
Year and Trim: 1991 Olds 88
Location: New Jersey - Most of Our Elected Officials Have Not Been Indicted
Re: Rear Struts Automatic Air Leveling...Blown Out Don't Work...
Post by Ol' Timer »
http://www.kyb.com/catalogs/index.php
You could go with KYB P/N 235025 with Strut Boot Kit #SB128. And you will have a "normal" rear suspension. It's not a difficult job for one person. Of course if you had a second person hold the shock in place while your threading the nut onto the top of the shock it would be easier. But then where's the challenge in that?
Other's will suggest Monroe Sensatrac.
2006 Salsa Vibe - Auto - Side Curtain Air Bags - ABS - Vehicle Stability Control - Tunes No Moon - Monotone - Preferred Package - Slate Cyper Cloth - Steelie Wheels
2002 Snap Orange Beetle - Auto - Turbo
1991 Dark Garnet Red Oldsmobile 88 - Donated to Science
