tire preesure on dic
- lynn37
- SSEi Member
- Year and Trim: 2000 SSEi Dark Blue Matallic
3.4 pulley
low pressure keeps comming on even tho the pressure is ok. i have had this happen before but i don't remember how to cancel it.
Re: tire preesure on dic
Press and hold RESET until it says normal, usually 10-15 seconds.
- Archon
Pressing the reset will just reset it for that ignition cycle. The next time the car is started, the tire pressure warning will display again. Keep pressing the select button, until "tire pressure low" is displayed. Now, hold the reset button until "reset" is displayed. That will take the 10 - 15 seconds. After releasing the reset button, the tire pressure should display "normal".
Oops, that's what I meant. Thanks Archon for clearing it up.
- In_da_boondocks
- GXP Member
- Year and Trim: '05 Impala SS
You may also have some dirt stuck by one of the sensors. I to me, it seems that going through a carwash and having an underbody spray done keeps that under control.
05 Impala SS: INTENSE FWI - INTENSE 180* t-stat - Autolite 104 plugs
1fatcat wrote:There are only two things I like to see in a bra, and a car is NOT one of them.
Or a WSS could be bad, or have a bad connection. If the ABS lights, or the traction control lights are on, that might mean a bad wheel speed sensor (WSS). They tell the DIC the tire pressure through comparing the rotation of the tires.
