A/C compressor replacement - question
Arriva
Year and Trim: 1996 Bonneville SE
Post by Arriva »
When A/C is off (1996 Bonneville SE non SC) compressor pulley makes noise and I see sparks coming off, I quit driving the car. When A/C is on mag clutch locks up and noise and sparks go away. I plan on replacing the compressor (been making noise also) and mag clutch.
Question: Will it cause damage to drive to A/C repair shop (after I install A/C compressor) to have system evacuated and charged?? No oil other than what is left in system -
alec_b
Year and Trim: 1996 SSEi, Bright White, Medium Teal, 197k
Re: A/C compressor replacement - question
Post by alec_b »
As long as you keep the A/C off no it won't hurt it. The oil in the system is only for the internal workings of the compressor, not the pulley. Leaving the compressor turned off essentially just turns the compressor into a regular idler pulley. You'll be fine.
Mods: Clear corners, gutted airbox, Alpine CDA-9886. Plans: 4x SensaTracs, high-flow, FM 80, 3.5 pulley, and for gods sake some good rubber.
Arriva
Post by Arriva »
Thanks for the reply, I have been driving my pick up but need to get going on changing the compressor. Saturday is the day.
Blownville
Post by Blownville »
My 98 is doing the same thing and I have been trying to figure out what step I want to take. I have replaced a clutch assembly on the 95 I used to have and I would do it on this one. However the puller I need is unable to be rented around here and I dont want to spend $75 on a complete puller/installer kit for any vehicle from Napa. When I did the 95 I used a puller that a friend of the family has but I cant get ahold of him to borrow it. If yo utake it to a shop for a compressor replacement they will require replacing other parts (don't remember the names of them of hand) in the AC system. I am thinking about calling a few shops to see if they can adjust the pulley for me though. There is a procedure for doing this but you need the correct puller. Good luck.
2003 SLE 145K PLIM, Tune, FWI, 180stat, Magnaflow cat and mufflers
1968 Galaxie Country Sedan Wagon 390/C6/2.75
First off, the system will not let the compressor come on without the A/C charged (unless the pressure switch is bad) to prevent the compressor from destroying itself on a low charged system.
Also, you need to have the system evacuated first. If you are changinging the compressor, you will need to remove the lines and it is dangerous and illegal to release the freon into the air.
fleettech2252004
Year and Trim: 1995 SE Black W/gold rims
Post by fleettech2252004 »
The shop will also recommend replacing the accumulator and orifice tube. That is also required for compressor warranty.
DAVE
'95 Bonneville SE
3800 series II
THE
BLACK BANDIT
gutted air box, drilled 180* t-stat, TR55s, belden wires
