Question on "Code 41" repair
Posted: Tue Sep 15, 2009 1:06 pm
Hi everyone.
I have a '89 Bonneville SE with an illuminated SES. I ran the codes and it is giving me a "Code 41". So something is up with the cam position sensor.
Searching through the forums, I read that I should check out the condition of the cam sensor interrupter magnet because that is usually the cause of a "Code 41". Sure enough the magnet looks to be damaged. Hopefully fixing it will remove the SES.
I'm planning to use the "Padgett method" sometime this weekend to fix the magnet.
The process looks fairly straightforward, but I do have a concern:
Because I don't have a soldering iron, it seems like the best approach is to just jab an awl into the magnet sprocket hole to break up and clear out the remaining pieces of the old/broken/missing cam magnet. However, it seems like doing this is doubtlessly going to cause most of the pieces to fall backwards into the engine's "timing" area. If this happens, is it safe for the engine? If not, what is the best method to remove the old pieces of the cam magnet using an awl?
Also, from what I understand the the magnet's sprocket hole should be completely cleared before the new brimless magnet is inserted, correct?
Thank You.
Thank You.
