PVC valve.
MStokes
- SSE Member
- Year and Trim: 97 Bonneville SSE.
PVC valve.
Does anybody know about a spring on the PVC valve? Changed mine out but found no spring. Instructions stated watch for a spring when removing cover. Got all o-rings inplace and put together but if it needs a spring, I'll have to find one. Thanks.
Sony MDX-C7900 running thru Bose system-CD changer in trunk-XM-Infinity tweeters. Autolite APP 605 plugs. New left lower control arm. New water pump, ICM, Crank sensor, MAP,TPS. Working on 2nd engine. Adding to car all the time.
- gonzo4191
- Year and Trim: 91 S10 P/U
97 SSEI- 136k - Location: round lake beach, IL
Re: PVC valve.
all the ones i've done had a spring
