99SE interchange with 97SSE
MStokes
- SSE Member
- Year and Trim: 97 Bonneville SSE.
Hey guys, will the PCM from a 99SE interchange with my 97SSE. Have a 99SE donor car. Also does the PCM have to be reprogramed when you do a engine swap.
Sony MDX-C7900 running thru Bose system-CD changer in trunk-XM-Infinity tweeters. Autolite APP 605 plugs. New left lower control arm. New water pump, ICM, Crank sensor, MAP,TPS. Working on 2nd engine. Adding to car all the time.
- agrazela
- Retired Gearhead
- Year and Trim: 04 Lesabre, Stock
98 Lesabre, Retired - Location: San Diego, CA
Re: 99SE interchange with 97SSE
1998-2002 all GM v6 PCM's are interchangeable (if you burn the right .bin file to them, of course).
1997 is not the same part, sorry.
Bone Stock
Retired
Bone Stock
Retired
