Trunk leak?
- 92BonnevilleSE
- Posts like an LN3
- Year and Trim: 97 Pontiac GP GT
Trunk leak?
I've got a trunk leak and was wondering if there was a common area around the trunk that leaked? The trunk carpet is mostly just wet on the driver's side. The weather stripping is brand new. Thanks
Joe
Rebuilt L36, Silverstar highs/lows and fogs, new brake lines, rotors, calipers, pads, ZZP Exhaust, Projector Headlights, Tinted Tails and Windows.
Mods to come- LED Tails, HID Kit, Top Swap (springtime)
- bill buttermore
- Retired Gearhead
- Year and Trim: 98 Caravan is the daily driver 215K
Re: Trunk leak?
Could be the seal around the rear window or more likely, the seals under the tail light lenses. Another possibility is rust through where the wheel well meets the trunk floor. To find out for sure, strip everything out of the trunk down to the painted metal; climb inside, close the trunk lid and have a helper spray with a hose until you find the leak.
1998 3.8 Dodge Caravan 214K
2000 3.3 Dodge Caravan 175K
- 92BonnevilleSE
- Posts like an LN3
Re: Trunk leak?
I might have to be the one that sprays.. I don't think I'll fit in the trunk.. lol. Im 6'8". But I will try doing that tomorrow.
Joe
- Archon
Re: Trunk leak?
Also, check the top of the wheel wells. Many rust through there.
- harofreak00
Re: Trunk leak?
I'm 6'3" 200lbs and I can easily fit in the trunk.
- 92BonnevilleSE
- Posts like an LN3
Re: Trunk leak?
I just took the backseat out so I could see better. I found out that the seal was pretty bad so resealed it and didn't notice anymore water leaks. It's raining right now so I'll check once it stops. Hopefully it's done!
Joe
- sandrock
- Retired Gearhead
Re: Trunk leak?
My '97 is also leaking. Turns out that the seam sealer has let loose near the tail light housing.
A good way to see where it is leaking is to run a garden hose over the top of the car, put a light in the trunk and take a peek through the passthrough. That's how I found my problem.
RegencyRoyale
- SSE Member
- Year and Trim: 1995 Oldsmobile Eighty Eight Royale LS
Re: Trunk leak?
My trunk leaks also. I'm pretty sure it gets in around the power antenna as the drain tube keeps slipping off. Take a look and make sure it's not that.
- 92BonnevilleSE
- Posts like an LN3
Re: Trunk leak?
after putting some sealant around, I haven't noticed any leaks. My 92 doesn't have a power antenna. I did check the antenna though but it was fine.
Joe
- bobfather99
- SSE Member
- Year and Trim: 1995 White Bonneville SE
Re: Trunk leak?
I ended up pulling the taillights and siliconing them back in.
Took care of my wet rearend!!
188340 Miles as of 06/07/10, still running.........
LIM/UIM Work done 4/23/07 at 145000 miles...
