oxygen sensor
oxygen sensor
where can i find the oxygen sensor on a '98 SE?
- zuper8
- Posts like an L67
- Year and Trim: 96 SSEi- 157K
Re: oxygen sensor
Look on the "back" of the engine, find your rear spark plug wires, specifically the middle one, and look below it, there should be the O2 sensor screwed into the exhaust. that's as best as i can describe it
dbeast420
- Year and Trim: Sapphire -1999 SSEi Metallic Navy Blue
Re: oxygen sensor
When / if you replace it though,soak it down good with some PBblaster before you try to remove it and pick up an ac delco. Bosch doesn't seem to agree with our cars
fuelforthesoul1999 wrote:Sapphire, of course, god that's the automobile equivalent of Halle Berry, you just want her.......
Without question, the greatest invention in the history of mankind is beer. Oh, I grant you the wheel was also a fine invention, but the wheel does not go nearly as well with BBQ!!
LeSabre in Buffalo
- Year and Trim: 2012 Eco
Re: oxygen sensor
X2 on soaking with PB Blaster before removing it.
When I did mine with a Denso direct-fit, I sprayed the sensor, drove a mile to the parts store to rent to special socket, drove back, sprayed it again, waited 10 minutes for the engine to cool, then popped it right out. Counter guy at the parts store couldn't believe I was returning the socket 40 minutes after renting it.
- repinS
- Moderator
- Year and Trim: 09 G8 GT
Re: oxygen sensor
^ Ditto to that, but I just used an open-end 21 or 22 (I forget)mm wrench. Took me longer to dig around the garage for the right tools than it did to take out the sensor! YMMV, though.
