Help With Air Mix
Blownville
Help With Air Mix
Post by Blownville »
ACDELCO Part # 1571835 {#16124942}
ACTUATOR,TEMP VLV w/A/C AUTO CONTROL(C61)
$53.79 $0.00 $53.79
ACDELCO Part # 1571923 {#16141822}
ACTUATOR,TEMP VLV w/A/C AUTO ELEC CONT(C68)
$63.79 $0.00 $63.79
Which of these two would be the correct air mix for my 93 SSEI?
Also is there a way to get the plastic that retains the actuator rod to the door arm or am I up a creek with ever fixing this? I broke mine when I disconnected it due to it being very brittle. Thanks all.
2003 SLE 145K PLIM, Tune, FWI, 180stat, Magnaflow cat and mufflers
1968 Galaxie Country Sedan Wagon 390/C6/2.75
skregal
Year and Trim: 95 SSEi
05 GXP
Re: Help With Air Mix
Post by skregal »
I'm not sure but my 95 was the #16141822.
Can't you look at your RPO codes and see if you have C68 or C61.
That may not be the correct advice, but maybe someone else will add something.
I would check a junkyard for the rod clip.
Blownville
Unfortunately I cant check my RPO codes anymore as I threw out the spare and cover. My trunk has a wood floor to make it even.
Does any one have a pic of the conection of the air mix door arm and the air mix actuator rod? I would like to see how it connects so I know what it is I would need to make or fab to get it connected. Thanks.
Post by gonzo4191 »
C61 - hvac system,air conditioner, front auto controls
C68 - hvac system,air conditioner front auto,electronic
you tell me :)
SSEi's are always going to have C68.
Have you looked at this? http://trialsnuts.com/ecc.pdf
Blownville
harofreak00 wrote:SSEi's are always going to have C68.
Thank you Andrew. The only pic that shows what I need is the one that has the Redneck fix attached to it. :)
I was hoping to find a pic of one that someone pulled the whole box out along with the door. I know its a long shot. :helpsmilie:
Guest
Year and Trim: n/a
Post by Guest »
Hi
The photo you wanted is in the trailnuts link #15
Blownville
Ahh I saw that one but I need the other end where it connects to the door. From what I gather it just snaps into a plastic piece that is always attached to the air mix door. I have kinda put this off due to buying a new toy! :wink: Thanks though.
