Page 1 of 2
hmm, rocker time
Posted: Fri Mar 27, 2009 2:59 pm
by MadMike
i wanna drop some rockers in
but
i need a solid parts list, and i cannot find a thread with one to save my life
so far i got. . .
Yella Terra Roller Rocker & Pushrod Package 1.8
Crow Cams105# Valve Springs
CompCams High Performance Valve Locks
Viton® Valve Seals
im not sure what else ill need anyone wanna chip in some insight?
Re: hmm, rocker time
Posted: Fri Mar 27, 2009 4:06 pm
by harofreak00
Coming from a guy with rockers... Cam it now, don't waste your time/money with rockers.
Posted: Fri Mar 27, 2009 4:13 pm
by MadMike
well, heres the thing, i plan on having both in time anyway,
im kinda copying todds mod list cam and rockers to lighten up the valvetrain
and the rockers i can install over a weekend,
instead of an entire week-2weeks in the garage, (i dont have that kind of time)
Posted: Fri Mar 27, 2009 4:28 pm
by harofreak00
You'd be installing rockers twice then. You can't have 1.9 rockers with a cam.
Posted: Fri Mar 27, 2009 4:30 pm
by MadMike
there 1.8 not 1.9 sir
and as far as i know, 1.8 and stage 1 cam = solid build
Posted: Fri Mar 27, 2009 7:22 pm
by 1337ssei
you can buy a special low lift cam that works with 1.8 and 1.9 rockers and provides the same like as an s1x or xp cams
Posted: Fri Mar 27, 2009 10:15 pm
by Allmachtige
MadMike wrote:there 1.8 not 1.9 sir
Try heads too.
I was young once and wanted to copy Todd as well, but that isn't how it works. Doing you're own thing builds a healthier sense of pride.
If you do rockers go 1.9's and you can get away with #90's. Rockers were a noticeable improvement on the 98.
As for "go cam or nothing", I won't jump on that statement yet because the work is not finished on my end, but it does have bearing....unless you blow a trans before a cam crossed your mind.
Posted: Sat Mar 28, 2009 3:54 pm
by MadMike
ok, well heres my plans for wat i have now,
wat im ordering and wat i want by the time im done
my current build is in my sig
im ordering 1.8.1 rockers and a few other goodies for the valvetrain
im also getting 105 valve springs, not 90. idk who said i was getting 90
after that, im not doing anything to the engine
im putting everything twards trans parts after that
then once the trans is built,
ill be getting stage 2 possibly 3 heads
and eventually the cam
my eventual goal is for 400whp, or 12.99 which ever comes first
Posted: Sat Mar 28, 2009 4:12 pm
by MadMike
either way, my main question was never answered!
is my parts list good?
Posted: Sat Mar 28, 2009 4:32 pm
by Allmachtige
MadMike wrote:either way, my main question was never answered!
I'd recommend replacing the stock retainers.
Posted: Sat Mar 28, 2009 7:08 pm
by MadMike
check! got those to
final parts list is as follows
Viton® Valve Seals
Manley Performance Valvespring Retainers
INTENSE™ Rocker Installation Kit
(Including valve cover gaskets)
Posted: Sat Mar 28, 2009 7:09 pm
by 1994se
valve cover gaskets, assembly lube, compression tester with an air hold, air compressor, torque wrench, oil change, coolant elbows (you have to take the alternator bracket off to get the rear VC off) and i think that's it.
Posted: Sat Mar 28, 2009 7:14 pm
by MadMike
coolant elbows?
i dont have to break them or anything o.0
both upper and lower are new
Posted: Sat Mar 28, 2009 7:22 pm
but they like to break, and are cheap to replace.
Posted: Sat Mar 28, 2009 7:36 pm
by MadMike
hmm, looks like ill be getting those too i spose
Posted: Sat Mar 28, 2009 7:42 pm
by willwren
Why 105's on 1.8's?
Why 1.8's instead of 1.9's?
Fuel injector o-rings, supercharger gasket, two yellow o-rings, coolant elbows, valve cover gaskets (grommets should be good), coolant, oil, filter, etc.
Posted: Sat Mar 28, 2009 7:46 pm
by MadMike
1.8 because i wanna do a cam in the next year also
105 because 90 seem a little weak for wat im planning to do
Posted: Sat Mar 28, 2009 9:06 pm
by willwren
"Seem" and "are" are two different terms. 105's are a bit much for 1.8's IMO.
My advice is to 1.9 now and forget the cam, or cam now and forget the 1.8's.
Posted: Sat Mar 28, 2009 9:16 pm
by MadMike
105# still work with 1.8 tho correct?
cuz for when i get the cam as well,
i know ill need 105 to handle both cam and rockers
Posted: Sat Mar 28, 2009 9:27 pm
by willwren
I think you're making a big mistake, and I'm going to strongly discourage you from that combination. Your choices from many logical standpoints should be 1.9 rockers OR a cam. If not ready to cam yet, save, and start getting ready. A new 2k cam install Techinfo is in the works right now, and is almost ready for release.
