I want to sand blast(prob use a differant media) the housing and really clean it all up, so thats why im asking...plus I just wanna take it apart,
Removing M90 rotors....
01bonneSC
Can some one point me to a link or give me a tip on getting the rotors out of my M90, 01 SSEi?
- harofreak00
Re: Removing M90 rotors....
Take the bolts out of the nose, remove the nose, then use a piece of wood or something soft to tap the rotor pack out of the case. Be sure to cover the needle bearings with duct tape so you don't get any dust in there. Also, don't wipe the grease off the ends of the rotors unless you want to buy new grease.
01bonneSC
Oi! What a P.I.T.A.! Still not out yet..
- harofreak00
Don't forget to drain the SC oil too.
01bonneSC
M90 dismantle....
ok, snout is off, trying to get rotors out.... i have tried tapping with deadblow and a piece of wood but no movement or anything. anyone else have tips or tricks to get the rotors out?
- harofreak00
I merged your posts, please keep this discussion in 1 area.
Isn't there a notch the bottom to wedge? I can't remember off the top of my head. There is nothing holding them in except for the gasket maker.
01bonneSC
Knew I shoulda posted this in General to begin with(more eyes to see post)...and i thought that would happen, lol
Nope no notch... machine a screw driver down thin and tried tapping that in but didnt do anything and I dont wanna mar up the aluminum. That sucker is on tight, and now rotors dont turn(i havnt hit it hard enought to damage the case), but I think something got in the case, so it def needs to come off.
trf_ssei
- GXP Member
- Year and Trim: 1998 bonneville SSEi
is the s/c on the engine still? if it is give it a few good whacks with a hammer and a block of wood it will come. try from different angles also.
01bonneSC
Its on the bench, im in process of doing LIM gaskets. I guess ill just keep trying....trf_ssei wrote:is the s/c on the engine still? if it is give it a few good whacks with a hammer and a block of wood it will come. try from different angles also.
01bonneSC
Got it! HAHA
trf_ssei
- GXP Member
good job. any damage while removing?
01bonneSC
I dont think so... maybe a bit of coating came off of one of the edges, its a *dang* tight fit to slide em out.
How clean are these things sposed to look? Im gussing the Teflon coating is black right?
- harofreak00
The rotor coating is actually gray, but dont' worry about cleaning them up. The carbon deposits on the rotors actually makes for a tighter clearance between the rotors, making more boost.
- willwren
- Retired Admin
- Year and Trim: .
The EPOXY coating is gray, there is no teflon. I certainly hope you have at the very least more supercharger needle bearing grease. Or preferably, new needle bearings, pre-greased.
Unless you have either one or the other, you should never remove the rotors from the case.
01bonneSC
Yup got new grease on the way. Didnt know how much of a pain it is to remove the bearings, I just didnt want to open a can of worms.
