If it ain't broke...
- spidey3479
- Posts like an L27
- Year and Trim: 2001 SSEI, 2004 SLE
Been reading about the trouble some have had with the LIM gaskets leaking. On the 01 SSEI, I am going to get my valve cover gaskets done to repair an oil leak, but I am not seeing any of the symptoms that others are seeing with the coolant leaking because of the LIM gaskets. Should I worry about that now or wait until symptoms arise?
1988 SSE-Gone but not forgotten.
2001 SSEI-304,572 miles, 3.5 Pulley, Intense PCM, Intense FWI Spectre filter, 160 tstat, ngk iridiums, belden wires, Silverstars-high and low beam, rebuilt tranny, shift kit, cooler, Dex VI fluid, replace the rear compressor and lines and level sensor, Monroe air shocks in back, FE5 struts and Moog strut mounts, Moog stabilizer bars, AC\Delco control arms.
2004 SLE-Stock, 195,000 miles,oldest son's baby now
2000 Ford Ranger-Stock, 352,000 hard, pizza delivery miles, new control arms (upper and lower), new(used) tranny
01bonneSC
Re: If it ain't broke...
If they are factory gaskets, they will more than likely leak due to the dex-cool eating them away. Its more a prevenative maintanance if you do not notice any coolant leaks, or coolant loss. I say just do em.
sco99888
- Year and Trim: 2001 se non supercharged
i would replace it unless you want to run into all the problems i had in my 01,it is not fun.
- Archon
It's a good preventative maintenance step. If you wait for symptoms, it may be too late.
I agree w/ Archon. It's like changing your oil. You don't change your oil when it needs to be changed, you change it every 3k, so you have fresh stuff in there. Throw the GM aluminum gaskets in, and have peace of mind.
And by too late he means you are going to get coolant in the oil and spin a bearing and then you are up crap creek without a paddle.
2000 SLE
swampthing
my car wasn't showing any symptoms until i looked at my supercharger one day and there was antifreeze sitting on top of my motor
Current fleet:
Current fleet:
- willwren
- Retired Admin
- Year and Trim: .
Do it now, or you may lose your motor.
RookieSSei
- SSE Member
- Year and Trim: 2002 SSEI
ALL STOCK (FOR noW)
yea been there done that im on motor 2 right not change them
