I know there were some questions about if a double din will fit so I thought I'd post some pics of mine.
I had a JVC before and it fit better because there were not as many wires behind the radio but overall both the units I had were fairly easy to install which is strange seeing how Best Buy and Circuit City telling everyone that it is impossible.
I was working at Circuit City when they announced closing so it being my second store I closed I knew what to do this time around and stashed some stuff and ended up getting some AMAZING other deals and getting this for $200 and the last JVC I had for $100.
It is the Pioneer AVIC-F700BT, the thing I like most about it is the hands free calling without even taking my phone out of my pocket. Very cool.
Night Hawk, The 4 door coupe
2 12" Pioneer Premiers in a vented box $350.00
2200 watt comp mono amp $200.00
7 inch Power Akoustic touchscreen 400.00
Setting off countless car alarms and making my passengers ears bleed... PRICELESS
Bugsi " then you could achieve that with fewer subs and still have (some) trunk space left over to carry groceries/body parts/etc"
Actually you can't. It disables all setting features under 10mph. But controlling the map and radio is rather easy while driving its just the settings and typeing in address' that you cannot do while driving.
Im assuming it wasn't plug and play, I've thought about trying to put a in-dash navigation in like that. Im interested in what kind or harness/wiring you used to hook it up.
-Tom
2003 Silverado Ext. Cab - Charcoal - 128,000 miles - Stock...for now.
2000 SSEi - Gone, but not forgotten.
Looong4 wrote:Actually you can't. It disables all setting features under 10mph.
I dont know if I like that, but I understand it's for safety purposes.
Yes its pretty much plug and play. I am useing the same adapter I used for a standard aftermarket cd player.
My steering wheel controls do not work and I believe there is a seperate adapter for that but I never used them anyways.
But basically all you need is:
Regular wireing harness
Antenna adapter
Dash kit
You will have to do a small amount of cutting behind the radio. I also had to run a gps antenna to the top of dash and a mic for hands free phone to the left side of the steering wheel.
I think that most nav units will not let you view settings just because it knows how fast your going via the gps.
Looong4 wrote:Yes its pretty much plug and play. I am useing the same adapter I used for a standard aftermarket cd player.
Antenna adapter
Dash kit
Interesting, I thought it would be harder than that. I might have to save up some money and get one.
-Tom
Wow that's a hell of a deal normaly these would go for 350 and up. That feature that disables typing while driving probably can be disabled. The shop who installed mine disabled the dvd feature so it can play while driving
2003 bonneville SE "Tha maroon monsta"- Blacked out tail lights..20inch gitano blades..7.5inch jensen headunit..2 kicker cvrs..2000watt boss amp..clear corner headlights..Red interior lighting..More to come...
yeah i did that on my last one by grounding out the parking brake lead, I did the same for this one but it seems like it knows your driving because of the navigation.
96 SE Pioneer AVHP5700 head unit(ipod connection) new are intake, clear corners, new foglights. HID head lights (Soon to have new rims) as soon as it gets warm enough.
ha... was just checking out your nav pics and noticed that we're neighbors. I guess it would have been just as easy to look at your profile info...but I didn't.
Anyway, hi neighbor.
~Adam
'99 SSEi
'02 Volvo S60 AWD 2.4T
'02 Jeep Liberty Sport
'89 Chaparral 187XL w/ 4.3L I/O Mercruiser
'00 Cannondale Jekyll 900SX
Follow me on twitter: adumb
Sorry to drag this one up from the dead, but what exactly did you have to cut in back? It's been a while since I've had mine apart, but I do recall it was a tight fit just to fit my single din deck in there.
The factory GM Navigation systems are like this too (though they might actually be like 5 or 8 mph). Father's 03 Yukon has a factory nav and it is like that. I believe this is the case in almost all (if not all) American sold OEM navigation systems.
1997 SSEi | Bright White | 170,000+ Miles | Stock | Best 1/4: 15.374
Yup, it's a matter of running a ground like alot of people do with their aftermarket DVD decks.
I did this when I put one in friends car. I forget what wire I had to ground out, but it shouldn't be too hard to figure out by looking at the wiring harness schematic if you have access to one.
DHP Powrtuner & Tech 2 1998 GTP Coupe 1999 SSEi 70k miles
2000 Trans Am WS6 LQ3 (LQ4 w/LS3 top end) 4L60E 2001 SLE
2002 Monte Carlo SS Top-swapped FSIC Gen V TOG's, Mezeire..... 2002 GTP 40th Anniv Ed Coupe 2004 GTP Comp G 'Bottom-swapped'
