Page 5 of 6
Re: 01 SSEi Cough under throttle BUMP for video
Posted: Tue Aug 09, 2011 8:49 pm
by wake
good deal
consider yourself lucky, go to page 3 to see how clean/spotless Will's (SSeiMan01)'s MAF is..you could eat off it
Posted: Tue Aug 09, 2011 8:58 pm
by CoastieWight86
Yeah, mine looked like that too so that is what turned me away from it the first time but when the second code popped up I figured I'd dump some more money into her and see what happens and it worked. I was skeptical as to whether that would be it of not.
Posted: Tue Aug 09, 2011 9:03 pm
by wake
yeah thats the messed up thing, his throws no codes and no lights..it had a misfire that threw a code, that was fixed by different plugs and better coils..
even after a larger downpipe/high flow cat and a new o2 sensor the cough is still there..
hes on vacation right now, when he gets back(and when andrew sends him another PCM) hopefully we can get that one to do a relearn and see if that fixes the cough
i guess you could say the threads on hiatus at the moment
Posted: Tue Aug 09, 2011 9:12 pm
by CoastieWight86
I hear ya. It is interesting to see how many different things can cause the same symptoms.
Posted: Wed Aug 10, 2011 12:12 am
by SSEiMan01
Yeah, I'm kinda just letting this issue bake in my head under the SoCal sun for a bit... Hoping its the PCM, if not then I'll swap MAF's with someone and see what happens...
Posted: Sat Aug 20, 2011 12:14 pm
by SSEiMan01
Well, as an update, I got back last night, and this morning went to try relearning the second PCM Haro sent me, FML!!!
Why will my car not relearn a PCM?
I followed the instructions on Intense's website and still nothing, the battery goes dead before anything else happens...
Posted: Sun Aug 21, 2011 10:52 am
by CoastieWight86
sorry about your luck. hope everything works out okay for you.
Posted: Sun Aug 21, 2011 10:02 pm
Will, how old is your battery? You can't tune if there isn't a full 12V, and the PCM won't security learn if it's losing power. Mine will stay on for far longer than the 30 min required for the security learn...
Posted: Sun Aug 21, 2011 10:15 pm
by wake
well we tried to do a case relearn today..for..are you ready for this?
almost TWO HOURS!
and it still wouldnt start
Posted: Sun Aug 21, 2011 10:17 pm
A security learn or a CASE learn? The security learn is with the key, on and off 5 times or w/e. CASE learn is with an Aeroforce or Tech II once it's running...
You know to have all accessories off and not open/close any doors, etc during the security learn, right?
Posted: Sun Aug 21, 2011 10:20 pm
by wake
yeah..security relearn my bad
yup, all four doors were shut, all windows down..radio was off
Posted: Sun Aug 21, 2011 10:27 pm
Check the date on the battery. Honestly, I'd replace it and see what happens.
Posted: Sun Aug 21, 2011 10:35 pm
by wake
had the battery sitting on the trickle charger most of the time..then got a high voltage warning..so we took the trickle charger off
the battery may have died once..but that was Wills fault not mine
EDIT: will just told me he got the battery in January
Posted: Sun Aug 21, 2011 10:38 pm
Start checking connections. All the grounds, both ends of the battery cables, etc.
Posted: Thu Aug 25, 2011 8:01 am
by SSEiMan01
Well, it repeated a stunt this morning that it decided to pull a few days ago, that may be related...
it started running rich (I could tell by how it smelled) and rough and would almost die, and once it actually did... After a minute it restarted but ran rough, so I drove home (a few blocks) with 2 feet lol... I checked the codes and now it decided to throw a p0103, which is MAF high input... I'm going to see about replacing the MAF today...
I'm hoping that this solves the cough issue, as well as the newfound rough running issue...
Re: 01 SSEi Cough under throttle BUMP for a code!
Posted: Thu Aug 25, 2011 7:08 pm
by wake
AHEM why didnt you update this?
Posted: Thu Aug 25, 2011 9:08 pm
Did it fix it?!
Posted: Thu Aug 25, 2011 9:15 pm
by SSEiMan01
AHEM! I've been busy all day...
Well, the running/stalling issue is gone thanks to a new MAF...
BUT the cough still exists, albeit fainter...I'm taking it to the shop I know Monday to have them relearn that PCM and if need be, diagnose this. With school going on now, I don't have time to do anything excessively time consuming with it
Re: 01 SSEi Cough under throttle, going to the shop! sadface
Posted: Tue Aug 30, 2011 4:49 pm
by SSEiMan01
Re: 01 SSEi Cough under throttle, FIXED! FINALLY!!!
Posted: Tue Aug 30, 2011 6:12 pm
by wake
