Page 34 of 62
Re: What did you do to your car today?
Posted: Thu Jan 28, 2016 10:16 pm
by haro1225
I had an idiot moment the last time the muffler fell off. I have a muffler that's about a foot too long for the 96 on there and I had it on there pretty good but it was sticking out due to the position of the Y pipe. I swapped them between sides and now they both fit, but of course it leaks now.
Posted: Mon Feb 01, 2016 9:08 pm
by bad.moshi
Replaced the front brake hoses and flushed the whole system. Gotta cash in on those rare 50° days in the middle of Winter!
Posted: Thu Feb 04, 2016 7:11 pm
by 1oldman
Just got back from having new "Wingfoots" "installed". Went to 235/60r16. Only driven them 2 miles so far. Can't wait to "see" how they handle on the road. Even made it a "tad" easier to enter and exit the car, if you know what I mean for an old man.
-BC
Posted: Thu Feb 04, 2016 8:26 pm
by haro1225
One of my 9012's went out so I swapped in a 9006 I had on hand. Haven't done the other side yet because laziness. Also probably put flat spots on my tires because I had somebody make a last second decision on the freeway and they locked up on me at about 60mph.
Posted: Fri Feb 05, 2016 2:13 pm
by BonnieBoy08
haro1225 wrote:One of my 9012's went out so I swapped in a 9006 I had on hand.
On the '96? Aren't those sealed beams? My '95 burned thru a passenger low beam about once every 3 months. Had to have been something in the wiring. But they were $20 or $25 a pop at walmart, not exactly in the high school/ college kid budget.
Posted: Fri Feb 05, 2016 7:50 pm
by haro1225
Somebody modified the sealed beam assemblies to accept a 9006. So I put the 9012's I had from before I did my retro.
Posted: Sat Feb 06, 2016 10:36 am
by MattStrike
I did that to my Camaro, it's basically the exact same bulb inside as the 9005/9006 but the housing is glued to the bulb instead of the normal twist fit. The shoulder and seal are the same, the only difference is the lack of retaining tabs. I used RTV and rubber tape to hold the 9005/6 bulbs to the housing. I was going to epoxy retainer from another headlamp housing next time I have to change a bulb to make it 100% drop in, but then I learned about some LED projector thats roughly the same dimensions...
Posted: Sat Feb 06, 2016 6:13 pm
by samples08
Picture does it no justice but I love it,
Now I just need to remove my Bonneville emblem on the truck
Posted: Sat Feb 06, 2016 9:47 pm
by BonnieBoy08
Truck or trunk? Looks pretty good. Where did you get that?
Posted: Sat Feb 06, 2016 10:07 pm
by samples08
Trunk SORRY lol at auto correct from my cellphone, and I got it on eBay for 14.00 free shipping
Posted: Tue Feb 09, 2016 5:15 pm
by Pontiac1
I have to start this post by saying that I love this car!!That being said recently I had some very pricey decisions to make.The subframe needed replacing and the trany was slipping.I decided that I really hate the newer cars along with the high price tags that come along with them.I now have a rebuilt trany and rebuilt subrame along with other parts to freshen up the front end.The car drives great!!I know a lot of people would scoff at pouring money into a car this old,she is a 1993 SSEi,I have had a lot of years with this car and plan to have many more. This car came from Florida and has almost no rust anywhere,the engine has 215,000 miles and runs awesome,I baby my car.I love the fact that these engines are easy to work on,and are very reliable.I think they are the best engine that GM put out and the reliability factor proves it.That is all,,,,,,,,
Posted: Wed Feb 10, 2016 6:32 pm
by brownishSLE
Over the warm weekend we had 2 weekends ago, I opened the trunk to look at the service parts label (was going to order touch up paint), and discovered that the carpet was very wet. There was about 2" of water in the spare tire well. I took everything out and dried it, then pulled the plugs out of the trunk lid (
these (thanks anwisdom)), then put everything but the carpet (still drying) back in. Hopefully that works.
This past warm weekend, I polished and waxed the headlights (long overdue), then cleaned the outside a little.
Checked the tires, because I knew the front right one would be low. I now know it won't hold air for more than a day
(I can hear the air whistling out of it).
It hasn't moved since early January, and it shows. It will definitely make a visit to the shop this month: tires holding air are the first priority, and hopefully the 60+mph shake as well. I get my license in March and I plan to start driving to school every day.
Posted: Thu Feb 11, 2016 2:52 pm
by BonnieBoy08
Re-installed my battery. My alternator went bad Tuesday night. I took my battery out and put it on trickle charger overnight. My alternator will be replaced under warranty, just need to go to the dealer after work and pick it up. Hopefully I can get it put in tonight.
Posted: Sun Feb 21, 2016 8:14 pm
by haro1225
Tried to jump the 04 because the battery was dead for some reason, didn't succeed but I managed to paint and install the SPO grilles that I snagged from the junkyard. Then I changed the oil in my friend's Vibe for her, and then I took pictures of the 96. I think it may be time to let it go, gonna post it on CL and see if I get any interest.
Posted: Mon Feb 29, 2016 12:04 am
by Benvw99
Posted: Mon Feb 29, 2016 1:12 am
by ddalder
I replaced the steering column telescoping actuator mechanism in the STS. Not a terrible job overall but requires a Tech2.
Posted: Mon Feb 29, 2016 4:40 am
by Blown93SSEi
Went to LKQ today and pulled off some door panel retainers, trunk torsion bars, trunk carpet, spare tire cover, idle air control valve, and trunk lock cylinder. Also picked up a k&n filter recharger kit.
Posted: Tue Mar 01, 2016 11:15 pm
by haro1225
A little late to this but I reached the breaking point with the noisy bearing on the beater so I replaced it on Sunday. It was totally gone as in the hub was really loose. I guess it will help the resale value without a howling bearing.
Posted: Tue Mar 08, 2016 1:48 pm
by haro1225
Somehow, the top nut on the strut cartridge came loose and the car was making all kinds of racket. Almost sounded like a broken axle. Fixed that last night and on that note it's officially for sale. Hoping I can make things work to get a different (aka better) winter/daily driver.
Posted: Thu Mar 10, 2016 11:16 am
by retroren
A funny thing happened yesterday to my Bonnie on my way back from buying a serpentine belt for my old Eldo. I stopped a red light and I could smell burning rubber. I got about 1/4 mile down the road and bam, I now am driving a pre-power steering car. I drive home, popped the hood to see a snapped belt and a frozen alternator. I knew I had a spare alternator that came with the car so I figured this is a cheap fix. Well, upon installing the spare alt, I realized it wasn't for my car. I went back to the parts store, picked up a new alt and belt. So much for a cheap fix. I don't know what made me give the new alt a spin while I was at the store but I am glad I did because it rattled. The new parts are installed and Bonnie is back on the road. Now I am fixin to paint the new front calipers black then install them with the black zinc drilled/slotted rotors that are supposed to arrive today. I'll post pictures of that job. That's it for now.
