Page 4 of 6
Re: 01 SSEi Cough under throttle BUMP for video
Posted: Sun Jul 31, 2011 1:28 pm
by SSEiMan01
That'd be fine with me, It'd have to be this week sometime in an afternoon, my last week of overnights and I'm leaving monday for CA... I was gunna call sinister monday and hopefully get it tuned this wekend... That's unless someone has personal contact with Kyle...
Posted: Sun Jul 31, 2011 1:30 pm
by gonzo4191
i have his number.....
he tuned my bonneville too
Posted: Sun Jul 31, 2011 5:10 pm
by 01bonneSC
In all honesty I dont hear anything unusual with that.
Posted: Sun Jul 31, 2011 5:14 pm
by wake
listen really closely its there..in the first vid he posted where it did it once, you can here it alot better than the second video..dont know why
EDIT: right about the 4-5 second mark you can hear it cough!
Posted: Mon Aug 01, 2011 3:09 pm
by Allmachtige
Sorry I rarely check this forum now.
I'll scan for free, just come to Aurora. I'll PM you.
Posted: Tue Aug 02, 2011 3:32 pm
by Ken_W
This is a shot in the dark, for if no other solutions turn up... could it be fuel-related? Bad gas? Time to replace fuel filter? Intermittent fuel injector problem? Have you used any fuel system cleaner lately?
Ken_W
Posted: Tue Aug 02, 2011 4:32 pm
by SSEiMan01
Ken_W wrote:This is a shot in the dark, for if no other solutions turn up... could it be fuel-related? Bad gas? Time to replace fuel filter? Intermittent fuel injector problem? Have you used any fuel system cleaner lately?
Ken_W
Possible, but its been happening for about a month, I've filled up numerous times. The fuel filter was done at 48k miles. And An Injector would throw a code even intermittently, I would think anyway.
Posted: Tue Aug 02, 2011 6:07 pm
by wake
i still think your PCM is toasted and not throwing codes
Posted: Tue Aug 02, 2011 6:19 pm
If his PCM was toasted it wouldn't run at all more than likely, or at least not well. Lots more things would also be tripping out.
Posted: Tue Aug 02, 2011 8:02 pm
by SSEiMan01
Unless it is a small glitch in the programming, it wouldn't necessarily make the whole thing bad...
Posted: Fri Aug 05, 2011 9:41 pm
by SSEiMan01
Just got back from Kyle's. Found some interesting things;
-Readings are goofy on some things, Kyle said he'll post with the scan, so I'll let him explain.
-Also, we tried swapping the PCM with one I got from Haro, and we could not get it to do a security relearn
-Basically we found the likely suspect to be the o2 sensor, I think somebody mentioned this earlier, live and learn... IF and this is a big if, I can find an AC Delco o2 sensor here in town tomorrow or at least by Sunday night, I will switch it out and see what happens... If not, I leave for California for two weeks on Monday, so I would just order it from RockAuto and have it waiting here for when I get back on the 19th. I have three places left to try one being, dare I say, the dealer. So I'm crossing my fingers, both that I can find this and that this fixes my issue.
Posted: Fri Aug 05, 2011 9:46 pm
by 01bonneSC
Hell Id just order from RA if you are gonna be gone for 2 weeks. Dont even waste your breath with the dealer.
Posted: Fri Aug 05, 2011 9:52 pm
by SSEiMan01
it would be a last resort and an unlikely one... Theres a ma and pa parts store here in town that stocks pretty much all delco parts so hopefully they have one...
Posted: Fri Aug 05, 2011 10:28 pm
by 01bonneSC
SSEiMan01 wrote:it would be a last resort and an unlikely one... Theres a ma and pa parts store here in town that stocks pretty much all delco parts so hopefully they have one...
Probably over the cost of what you can get at RA.
Posted: Fri Aug 05, 2011 11:30 pm
by CoastieWight86
First off, I am new to this site but not the car. I have an 01' NA with 130k on it and I am having pretty much the same issue. I have replaced a broken vacuum line, lower intake gaskets, upper manifold w/ gaskets, I did a full tune up with OEM plugs wires and ignition coils. Also a fuel filter and cleaning of the throttle body and MAF. All of this with no results, after speaking with a friend of mine who has been a mechanic for 15 years he has told me to check the torque converter. I haven't done this yet but it might be worth a shot.
Posted: Fri Aug 05, 2011 11:41 pm
by 01bonneSC
CoastieWight86 wrote:First off, I am new to this site but not the car. I have an 01' NA with 130k on it and I am having pretty much the same issue. I have replaced a broken vacuum line, lower intake gaskets, upper manifold w/ gaskets, I did a full tune up with OEM plugs wires and ignition coils. Also a fuel filter and cleaning of the throttle body and MAF. All of this with no results, after speaking with a friend of mine who has been a mechanic for 15 years he has told me to check the torque converter. I haven't done this yet but it might be worth a shot.
Do you know if your 02 sensor has been replaced?
Posted: Sat Aug 06, 2011 10:30 am
by CoastieWight86
No, it is original.
Posted: Sat Aug 06, 2011 2:26 pm
by 01bonneSC
CoastieWight86 wrote:No, it is original.
Good maintenance item to replace.
Posted: Sat Aug 06, 2011 2:40 pm
by SSEiMan01
Not likely to fix the problem though. I just did mine and It didn't change anything.
Also I cannot for the life of me get the PCM I have to relearn to eliminate that possibility, I tried for about 2 hours and didn't get a thing out of it except aggravation.
Boy do I need this vacation, for many reasons that are causing me stress, one of them being stupid little issues like this.
*end rant*
I don't really know where to go from this point, but likely that it'll have to wait two weeks until I get back.
Posted: Tue Aug 09, 2011 8:43 pm
by CoastieWight86
So, I was on my way up to the trans shop to have them take a look and another CEL popped up for a MAF sensor. I had only cleaned it when this code popped up a week ago. Well I swapped it in the parking lot of the local parts store and had them clear the code again. When I drove off, no more hesitation. What a relief.
