Intak gaskets done and Running!!
Bob Dillon
Re: Engine unlocked-Now to get it running
Post by Bob Dillon »
LeSabre in Buffalo wrote:I can see where they want the coolant going through the TB in cold, wet climates where the TB can ice over.
It would be interesting to know throttle body temperature under the hood even in a cold climate. And the exhaust heats up much more quickly than the coolant. I'll bet in my climate (seldom gets under 45) it's just not needed, but of course GM has to engineer the car for the coldest climate in which the car operates.
To the OP: Let us know how things turn out!
Yes, please. I certainly hope there was no internal damage.
LeSabre in Buffalo
Year and Trim: 2012 Eco
Post by LeSabre in Buffalo »
The temperature of incoming air has a lot to do with the TB icing or not. For those of us in the north (or where it gets to 32* F/0* C regularly in the winter) it's possible to have a cold, humid day. The wet, cold air comes in, chills the TB, and ice forms since the TB eventually drops below 32* F. That's the reason for the coolant passages in the TB. I took off the TB coolant lines on a previous car, and it did ice up the TB one very cold, wet night. It was scary going down I-90 with my foot on the floor barely making 55 mph...
I've also seen intake air temperatures well below freezing on my ScanGauge in the Buick. It doesn't like air much below 30 degrees, else it knocks up a storm.
To the OP: if there are any other gaskets/plugs/wires you'd like to replace now that you have the access, now is a good time to do so.
94SilverSSEi
Year and Trim: 97.2 40th SLE
68 w/400
94 SSEi
Post by 94SilverSSEi »
I think Ill just say with the standard plenum as I am sick and tired of messing with this POS engine tht I wanted to replace altogether to begin. Oh well nothing I can do now.
Will be changing oil and flushing oil again today and ordering plenum tonight and hopefully it'll be here by Friday or Saturday. And I am just praying that none of the rods are bent and I'm assuming there not as it seems to tub over fine but will be doing a compression check anyways.
More updates later
Clay
1997.2 40th SLE-138k
1999 GMC Suburban SLT-191k
2005 Escalade 253k-GINA
1fatcat
Year and Trim: before cars
Post by 1fatcat »
Do a compression test. An engine with a bent rod will turn over just fine. Chances are the rods are fine, but now is the time to check the compression.
LeSabre in Buffalo
Yeah, what he said.
You're ordering the APN UIM, correct? That's a good piece, it's working well on my car and many other members' cars.
94SilverSSEi
68 w/400
94 SSEi
Well yes and no. I will betalking to a friend at the dealer and seeing what kind of deal I can get since I dont need that whole kit but i doubt he will be able to get me anything cheaper although that would be great then I could have it back together by the end of the weekend.
Otherwse I will be ordering the APN kit and then having to wait and then it prolly wont be done for 2 weeks :sad5:
Clay
94SilverSSEi
68 w/400
94 SSEi
Testing cylinders as we speak:
number 1-130psi
oh. Btw what is the compressionsupposed to be?
Similar for all cylinders I know but I mean for these motors in general.
It seems like I saw 120-150 psi somewhere???
Clay
repinS
Moderator
Moderator
Year and Trim: 09 G8 GT
Post by repinS »
We would probably need to see all six cylinders before coming to a conclusion.
94SilverSSEi
68 w/400
94 SSEi
I only had time to do one. Ill get to the other five tomorrow. And well see. It seems like it turns over okay and everything. So I've got my fingers crossed
Clay
Its not necessarily what pressure, all that matters is that they're all the same.
willwren
Post by willwren »
That's not true at all, Ed. The pressure does matter quite a bit. Let's see all the numbers and we'll talk more about it. I'd also like to know your technique. HOW you use that gauge can affet your readings.
Bob Dillon
willwren wrote: HOW you use that gauge can affet your readings.
Yup. Making sure the throttle body is blocked open is essential for an accurate compression test.
1fatcat
Post by 1fatcat »
True, but 130 is just fine. So as long as the other 5 are 125-135, there should be nothing to worry about.
94SilverSSEi
68 w/400
94 SSEi
Update: Got new plenum today. Have a friend at the dealer and got it for $79. I figured why wait 3-7 and pay another $26 for all the extra crap when I already bought it then I can have the car done this weekend.
Also obviously the top of the motor is not on so we just turned over the motor for 10 seconds with key and it read 130psi
Clay
1fatcat
Post by 1fatcat »
No news on the other 5 cylinder readings?
94SilverSSEi
68 w/400
94 SSEi
Nope havent tested them yet. We'll be testing the other 5 cylinders tomorrow and WILL be putting the motor back together.
I dont believe any of the rods are bent as it seems to turn over fine and doesnt show any signs :) I hope :bhuh:
Clay
Motor turning over fine doesn't mean anything. Rod can be bent and have no signs. The compression test will tell all.
94SilverSSEi
68 w/400
94 SSEi
00Beast wrote:Motor turning over fine doesn't mean anything. Rod can be bent and have no signs. The compression test will tell all.
And that is why that will be the first thing we do tomorrow before we start putting it together :)
Clay
94SilverSSEi
68 w/400
94 SSEi
Well cylinders 1, 3, 5 all testeD between 130-140. The backs are too much of a biotch to do so we said just screw it.
Motor should be back together today. The WHOLE oil filter was filled white crap. Assuming it is burnt colanty oil. After the second oil flush. The oil was clean.
Clay
J Wikoff
Post by J Wikoff »
I got my fingers crossed for you.
