I will fix your 2000+ radio display bulbs
Oldman
- Posts like an LN3
- Year and Trim: 2001 SSEi
Re: I will fix your 2000+ radio display bulbs
Can you tell me how to get to the bulbs on the steering wheel? I'm scared I'm going to break something or have the airbag blow up in my face!!
The soldering I can handle.
Thanks,
Thanks,
- harofreak00
Just pull the button pod straight out. Its not held in with anything but friction. The wires behind are kinda short.
Its not the soldering, its finding cheap LED's.
Oldman
- Posts like an LN3
I've got a couple of "donor" radios around. Are the steering wheel controls clear or red?
Thanks,
Thanks,
- harofreak00
Red. Finally found the pics I was looking for.
Oldman
- Posts like an LN3
Thanks again,
would a board from a stereo have any bulbs like these?
- harofreak00
Doubt it, but I have no idea what stereos you have.
- harofreak00
Still getting PM'd asking if I still do this. Yes, I do, getting pretty good at it too.
95SLE
- Posts like a Northstar
- Year and Trim: 2004SLE
Any thoughts of using LED's instead of incandescent bulbs?
2004 SLE Crimson Tintcoat with Dark Pewter Interior. Mods so far: Wood Dash Kit-Window Tint-CATZ Fog/Driving Lights
Custom Fabricated Stainless Steel Mesh Grill-Painted Calipers-3rd Brake Light Decal-Strut Tower Brace.INTENSE™ Level 1 L36/L26 Performance Package, Intense Shift Kit. ZZP ER Rockers and a HV3. L76 springs
COTM April 2007
I know this has been covered, and LED's have so much less resistance that something in the board would be all goofed up unless you used a resistor.
- harofreak00
The whole LED idea has been covered in the tutorial: http://www.pontiacbonnevilleclub.com/fo ... 88&p=7402795SLE wrote:Any thoughts of using LED's instead of incandescent bulbs?
95SLE
harofreak00 wrote:The whole LED idea has been covered in the tutorial: http://www.pontiacbonnevilleclub.com/fo ... 88&p=7402795SLE wrote:Any thoughts of using LED's instead of incandescent bulbs?
Thanks for helping me out.
COTM April 2007
- harofreak00
Still getting PM's, still doing this.harofreak00 wrote:Still getting PM'd asking if I still do this. Yes, I do, getting pretty good at it too.
- sm in Georgia
- Year and Trim: 2000 Bonneville SLE
This may be a stupid question
but my stereo no longer shows what station it is on or what song etc like it used to. I checked into a new stereo - dealership is like $500, if I get a new radio elsewhere, the steering wheel controls will no longer work. So I just put up with never knowing the station!! Is the issue the bulbs? The radio itself works fine, plays cds and tapes!! Do I have to send the whole radio or does that section pop out?
Sheila-Marie
2000 SLE - Silver with SunRoof
Sheila-Marie
Sheila-Marie
2000 Pontiac Bonneville
[IMG]http://i102.photobucket.com/albums/m94/GEMS1965/Bonnevilleinsnow2011.jpg[/IMG]
- *B2*
- Posts like an L36
- Year and Trim: 2000 SLE - Black
I'm sure Andrew will be around to answer this himself, but yes, your bulbs burned out. Andrew can sell you a stock stereo with new bulbs for MUCH less than $500, and your steering wheel controls will still work. I bought one from him a few weeks ago, and it is very nice to have my display back.
Black 2000 SLE
- harofreak00
Yes I can help you, PM me for details...
03brokenSSEI
- LE Member
- Year and Trim: 03 Pont Bonneville SSEI
This is an older thread but are you still installing display bulbs? I am interested. I'm working with an 03 Bonneville. I have a blank screen after disconnecting/reconnecting battery terminals but radio/cd still play. I'm thinking maybe the voltage spike from reconnecting the terminals popped the last working bulb on the display...
Do you still do these?harofreak00 wrote:Yes I can help you, PM me for details...
Do you still replace the bulbs on the A/C heater control module?
- harofreak00
Yes I do. You can PM me here or email me at andrew.suderman@gmail.com
- redfury
- Posts like an LN3
- Year and Trim: 2000 SLE Saved from the scrapyard.
on the subject of bulbs, can I assume that the DIM has bulbs as well? I haven't looked closely at mine, but it doesn't light up at all in my car, and I haven't seen any other pictures of a lit dash that shows the DIM module. If it is lit, then I'd have to assume it has the same surface mount LED's as the steering wheel controls?
Also, I found 12v SMD style LED's with a good spread in multiple colors on ebay for a decent price. They worked really well in my Cluster light replacement. The hardest part was figuring out the polarity of the circuit for each light.
